Previous in Forum: Is This So Overmatched and Costly Electrode Neccessary   Next in Forum: Shower Foam Removal from Mixing tank
Water Soluble Bio-Safe Cutting Fluids
06/17/2013 2:30 AM
Hi people
Can anyone recommend brands and types of water soluble cutting fluids for a small workshop with intermittent machining hours ?
We want to avoid bacterial growth when not being used
minimise evaporation losses
minimise atomisation into atmosphere as we dont have a fume extractor
We will be using 1020 , 1045 , 4140 , 4340 steels for 99 % of work and the rest being cast iron and aluminium.
products available in australia are preferred
thankyou folks
Good Answers: 94
Re: water soluble Bio-safe cutting fluids
06/17/2013 4:17 AM
We use Rocol Multisol in our lathe & mill. The lathe is used perhaps a couple of times each week whereas the mil will sometimes go a couple of weeks between uses. We don't have any trouble with bacteria, hard to say if we get evaporation but, as the fluid drains back into the coolant pump sump, I would have thought it was minimal. We are cutting stainless 304 & 316, nickel alloy steel, aluminium & Delrin.
06/17/2013 8:18 PM
thanks Nigh
i will compare the rocol one with hocut 795 i have also looked at
cant believe this got only one reply . .
must be more people on earth using cutting fluids than just one guy lol :)
Jack of all trades . master of four or five
06/18/2013 11:09 AM
I can't comment on the rocol but we have been very satisfied with the Hocut 795. have been using it for ~5 years. Evaporation of the water is to be expected. Would suggest the use of refractometer and maintain the concentration between 5 - 6.5 percent.
That which is watched, is optimized.........
06/18/2013 7:54 AM
I solved my problems with mold and fungal growth by using a mixture of WD40 and automatic transmission oil. 50/50 Drill bits last a lot longer but there is some losses due to evaporation of the WD 40. You will still get some smoke on hot turning so if that is a problem then ignore my suggestion. There is also some additives to prevent this growth from occurring not sure of the names but used them at one factory I worked in.
Re: Water Soluble Bio-Safe Cutting Fluids
06/26/2013 12:34 PM
Hi I have a similar requirement, but haven't bother to ask the question......
However, I was interested in a recent article which suggested the use of copper door handles in hospitals as the copper is effective at suppressing MRSA and other "super-bugs" ...... so why aren't we both putting some strips of copper / copper wires in our sumps?
As a semi-aside (but to illustrate the power of copper in this sort of situation) copper compounds are regularly used as garden fungicides and copper is also very effective at suppressing tree / plant growth.
phil
If you can't explain a concept in simple terms, you don't understand it well enough.
07/26/2013 4:09 AM
Try NOCO BIOCOOL 100
dieselphil (1); HeadsUp (1); MrM (1); Nigh (1); roy hammy (1); TimBurks13 (1)
