Previous in Forum: Modal Analysis Using Ansys Workbench   Next in Forum: Weldolet With Different Header Thickness
Shop Fabricated Tanks
06/17/2013 6:59 AM
Dear All,
We have designed a brown field storage tank terminal (Mainly Chemicals, Partially hydrocarbons) for one of our clients located in the UAE. The tank diameters are 9M and 11M. One of the EPC Contractor came out with a suggestion of prefabricating these tanks and erect/install at the location. As per API-650 Appendix - J, the same is however permitted only for the tanks having diameter 6M and below.
With the recent fire in the Jabel Ali Free Zone, Dubai, client has asked us to review the EPC Contractors request, as prefabricated tank will reduce lot of site welding and in effect will increase safety. We are in a situation where the Contractor is confident of doing the work in shop and erecting at site, shop fabricated tanks will have better quality and adds to safety at site but API 650 does not allow the same.
Can the forum give the direction to this subject?
Thanks in advance,
Best Regards,
A.Raghuraman
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Knowledge is power
Good Answers: 38
Re: Shop Fabricated Tanks
06/17/2013 9:08 AM
Quality, field fabricated tanks are nothing new.
API-650 applies to both partially and complete field fabrication.
Discuss details of the degree of field fabrication with your contractor. Ask about the success of other jobs that he has done in this manner. Get references and talk with them.
Review the specific differences of installation, inspection and testing of API-650 field fabricated versus shop fabricated tanks.
Hydotesting and liquid disposal is a big issue
06/17/2013 9:10 AM
This will be a decision made by the customer and his insurance carrier.
My advice is to go with the code. But, I'm not there, not part of that culture nor never been in that part of the world, and never want to go.
Either follow the controlling documents, or throw them away.
06/18/2013 10:14 AM
There are several issues to analyze here:
1.- If the tanks are pre fabricated then transported, and then assembled and welded, the different QA/QC steps in between have to be carefully monitored, since damage to welds, over stressing welds, etc., may affect the final quality of the tanks.
2.- If the tanks are pre fabricated, what is the size of the sections, since there are transport, damages, etc., and other considerations to be reviewed.
3.- Generally a pre fabricated tank like what you are mentioning, require Post Weld Heat Treatment to relieve the stresses caused on the metal.
4.- The client and their insurance carrier need to address the cost of the transport hazards.
5.- Review the contractor who will perform the work and have a group of inspectors there to assure that all the steps and tests are performed prior to shipment and that the contractor will repair any and all issues that may arise on the job site.
If all of these steps can be resolved then you can almost surely do it that way.
07/03/2013 9:54 AM
Thanks a lot for all your valuable replies.
Say, Tank Contractor situated inside the free zone itself near to the site. Hence, transportation won't take much distance (But have to transported through road).
Tank Contractor agreed to follow Appendix-J -Shop assembled storage tanks.
And if all your above points agreed by Contractor, Shall we still indicate API 650 as design code?
Is this not violating API 650 requirements?
If we accept Tank contractor for shop assembly, Do we have to face any other complications?
Need your expert advice...
Knowledge is power
Register to Reply 4 comments
lyn (1); maraamaram (1); MJCronin (1); vargaalex (1)
