Previous in Forum: Low IR Reading on a Cable   Next in Forum: Earth Conductor Sizing as Per IS 3043
8 comments
Why WTG Has No Effect on This Circuit?
06/18/2013 1:13 AM
I have made a simple circuit WTG,WTG on the circuit but this does not affect the current, voltage, and power generated.although WTG is disconnected from the circuit, the circuit will still get a power source,how do I order this WTG can set the current, voltage, and power generated?
is there any one who can make me an example of a series of wind turbine generator that can run on etap 6.0.0?
Re: why WTG has no effect on this circuit?
06/18/2013 2:17 AM
06/20/2013 12:14 AM
sir,, can you give an example for wind turbine generator simulation? please sir,, im not understand with my problems...
Re: Why WTG Has No Effect on This Circuit?
06/20/2013 12:17 AM
06/20/2013 1:29 PM
So ,
PC simulation reads power even if WTG is isolated . - Is this about PLC scan time for updating the reading value or last value gets highlighted because of sample and hold function of measuring instrument hence etap 6.0.0 ?
" WTG , after getting disconnected " - May this mean that WTG is in OFF state or of otherwise ? This OFF state could bring the same situation ! , Is it so ?
If not so , field bus status / GPIB for Measuring instruments - needs observation .
If so , I have to go through about etap & WTG . Your feedbacks will be of atmost importance so as to conclude . Regards .
06/20/2013 10:12 PM
no sir,, in this simulation i just want to observe how the influence of wind speed against power, voltage, and current is generated?..
i've tried to change the wind speed, but it had no effect... even if i disconnect the WTG, This simulation can still generate power? Which of power, current and voltage come from? can you give me an example about this?
06/21/2013 2:52 AM
Simulator is unable to accept different wind speed scenario .
Perhaps , you could have installed this software in another PC and tried out this case ( Not as a program ) .
The basic function of simulator , by going back to default choice in options ; we must get .
We should prefer to check the procedure for feeding wind speed and its Inhibit . Through another PC or as another program - in these two ways - need to work out . Let this be checked out .
06/21/2013 10:03 AM
http://www.youtube.com/watch?feature=player_detailpage&v=bS4n8OM-T1k
With 5.5.0 version , it is explained . Through Macros - we simulate the situation . Here , I/P parameter for us would be of varying type ; not as digital I/P or stationary one .
http://www.youtube.com/watch?v=bS4n8OM-T1k
With 6.0.0 version , this is explained . This deals with an example . After going through this , I will respond . Thanking you .
06/22/2013 12:56 PM
With 6.0.0 version , it has one example . As well , few other presentations - in this topic were available . You would be convinced so as to proceed further . I hope you are into that . Regards .
Register to Reply 8 comments
Shanders (3); sivaa (4); SolarEagle (1)
