Previous in Forum: Why WTG Has No Effect on This Circuit?   Next in Forum: Common ESD Trip
9 comments
Earth Conductor Sizing as Per IS 3043
06/18/2013 3:17 AM
The earth fault current dissipates throuh earth conductor surface area for which we also check necessary dissipation area . Please inform then why we are bounding minimum cross section area of earthing conductor by Ixroot(t)/k.What is the significance of this cross section of conductor?
Re: Earth Conductor Sizing as Per IS 3043
06/18/2013 8:55 AM
06/19/2013 5:16 AM
06/19/2013 8:53 AM
dhayanandhan,
Suggest you look again.
Scroll down and after the first page "Disclosure to Promote the Right To Information" and a blank page you will see that all 85 pages of Indian Standard CODE OF PRACTICE FOR EARTHING (First Revision)
Fourth Reprint June 2007 UDC 621316.99 : 006.76 is there in its entirety.
At least, that's what I get on my PC.
06/19/2013 12:36 PM
Dear Mr. lyn,
Thank you very much for your guidance. Now I got it. When opened earlier, except the 1st page RIGHT TO INFORMATION, NOTHING WAS THERE.
DHAYANANDHAN.S
06/19/2013 7:09 PM
dhayanandhan,
That omission may have been caused by the switch over of servers performed earlier today by sparkies.
There were many blank screens and blank parts of screens today, till the switch over was refined and the electrons were properly restrained and taught where to go.
Kindest Regards.
06/18/2013 1:52 PM
I have read that code in details with latest ammendment but not understood .Pleasae help
06/19/2013 3:34 AM
Consult an Electrical Engineer locally.
06/19/2013 4:52 AM
Keep reading....... Small hint: the selection of cross section of conductor is a function of time withstand capacity of the conductor, which in turn is based on required design defined parameters. This is the start point of any earthing system design.
Good Answers: 170
06/20/2013 3:04 AM
I wish you read IS 3043 a bit more carefully. In India, we largely follow the TN-S system, in which there is a dedicated, separate earthing protective conductor, to carry the earth fault current back to the source. Thus, in such a system the earth fault current does not flow through the natural earth. It is also documented in the first section of IS 3043 itself wherein it is stated that "the earth now rarely serves as a return path for the fault current....".
Thus, as a metallic conductor is going to carry the earth fault current, the cross section of the conductor is very much significant. (Ohm's Law)
Register to Reply 9 comments
dhayanandhan (2); electricalexpert65 (1); lyn (3); Pattabhiraman (1); PWSlack (1); saraswata1981 (1)
