Previous in Forum: Daily Target   Next in Forum: Heat Being Repelled by Cold?
17 comments
Simple Pressure Sensor/Switch - South Africa
06/30/2013 7:10 AM
Dear All
I am looking for ideas to make a simple/inexpensive water pressure switch/sensor that can detect someone opening a water tap. Max water pressure is 600 Kpa with taps closed. Water temperature would be in the range 5 to 80 degrees C.
Ideally I would like to measure the actual pressure or extent of any pressure drop but otherwise simply that a tap has been opened which may be the easier option.
The device can be inserted inline or in a T junction in the pipe to measure pressure.
The sensor / switch would be input to a MCU so a digital or analogue output would be required.
Any ideas - both mechanical and electronic please?
Thanks and regards
Mike
Re: Simple pressure sensor/switch - South Africa.
06/30/2013 8:38 AM
is Google broken today?
06/30/2013 10:04 AM
It's always broken.
Having someone do the leg work for you seems to be the way work is done now.
I'll go one step further: OP Google "pressure transducer"
Can't anybody do their own work any more?
Re: Simple Pressure Sensor/Switch - South Africa
06/30/2013 11:45 AM
this might work
06/30/2013 12:08 PM
Use a flow sensor. They react to water flow rather than pressure change.
07/01/2013 7:04 AM
I agree simple flow switch is the best method.
This is a short tube screwed into the line which has a piston and a light spring this will move when the water flows through it, a small magnet mounted in the piston can activate a reed switch on the outside of the tube and switch whatever indicating system on. It could even be rigged to an electro mechanical counter to indicate how many times it has been operated.
The flow switch is so simple you could make it your self.
07/01/2013 7:26 AM
Dear All
Today I purchased a VW oil pressure switch for under $5 US and will try that out.
Not sure at what (lower) pressure it will close the contacts but I will play with it to test.
Thanks to Oraka for pointing me in that direction and to others with some good ideas.
Regards
Mike
07/01/2013 6:08 PM
mviljoen, I don't know about a VW oil pressure sender, but many senders are analogue devices so they (with a bit of signal processing) will tell you the pressure in the system. If it is only a simple switch, i.e. if the vehicle has an oil light as distinct from a guage, it may not change state until the pressure is down to 5psi (30kpa) or so and that may be too low for your purposes. Ask your local auto-electrician for the best sender for your project.
Good Answers: 183
06/30/2013 1:03 PM
Look at CiTy Sensors on the net they have sensors insensitive to water cold or hot and a simple assembly for transducers as well as the conditioner which works with the sensor. It is an interesting solution since their membrane is ceramic Al2O3 and does not allow a deposit if water is hard. Write that Nick Name gave you the hint
Good Answers: 59
06/30/2013 9:56 PM
Silicon sensors are widely used in washing machines, dishwashers, tire inflation indicators, etc. They are available from electronic parts catalogs for any pressure range you can desire. Price range varies.
06/30/2013 10:56 PM
An oil pressure sender unit from a car/truck/tractor will do it.
07/01/2013 3:02 AM
Thank you - excellent idea!
06/30/2013 11:07 PM
How about a 'simple water pump pressure switch as fitted to almost every domestic water supply I have seen in africa. I have also seen racks of them in almost every little hardware store. They are designed to turn on the pump when the tap is opened.
Hang on, lets reinvent the wheel!
07/01/2013 10:39 PM
But could of course be used to switch any form of alarm, light or buzzer you want to uise to inform you that a tap has been opened/
(happy now Oraka?)
07/02/2013 1:32 AM
Not if, as I said, it is a simple switch whose switching pressure was below the level that the system would fall to when a tap was opened. Hence my advice to get an analogue sender.
06/30/2013 11:42 PM
A pressure switch called a Hobbs switch can be set for almost any pressure drop or increase in multiple pressure ranges. At my last purchase they were made by Honeywell. Duke
07/01/2013 3:44 AM
As happens far too often, many who replied to this subject did not bother to read the question properly. The guy wants to be informed when someone turns on a tap in his system. That is all he wants.
I think it is crazy for some replies to be given GAs when, in fact, they are off topic.
Good Answers: 59
07/01/2013 8:22 PM
A minor detail.
A sensor, built for cold / hot / soapy water has to be built with electrocorrosion in mind.
Therefore, the silicon sensors I recommended, and the electromechanicals from a plumbing supplies will last.
A pressure sensor built for oil lines are not built with corrosion in mind. There dissimilar metals are mixed freely.
Other than that, I have no strong opinion on the matter.
Register to Reply 17 comments
Fredski (2); garth (1); HeHound (2); leveles (2); LOCKDUKE (1); lyn (1); mviljoen (2); nick name (1); Oraka (4); tcmtech (1)
