Previous in Forum: Instrumentation Material   Next in Forum: HVAC Monitoring Equipment Options
Leek Test
07/07/2013 3:21 AM
Dear All
In instrumentation any standard for leak testing of impulse tubing. cause during the document review our client agreed to use water to carry out the test, however procedure have been request by using N2. any advise
Regards
Good Answers: 92
Re: Leek test
07/07/2013 7:21 AM
As per Willy Wonka's factory manual;
".....in situations where the anonymous poster has given totally insufficient data to determine the practical application, let alone specific parameters of any test protocol, and especially when the request for information includes substitution of a liquid for a gas in the testing methods, the universal opinion is that you shallot use leek juice instead until such time as said anonymous poster provides further and sufficient data."
Re: Leek test
07/07/2013 8:42 AM
I think that I accurately remember that a liquid will be a safer pressure testing fluid than a gas because a liquid is not compressible.
Re: Leeky peeky
07/07/2013 9:13 AM
Yes, there are standards. They would be obvious to anyone with knowledge of instrumentation.
Hire a consultant, or do some research on the web.
United States - Member - New Member Engineering Fields - Instrumentation Engineering - Popular Science - Cosmology - Beam me up Scotty!
Re: Leek Test
07/09/2013 12:05 PM
If the procedure asks for Nitrogen, Use Nitrogen, The customer is relying on you to perform a professional service you should be embarrased to ask Their opinion, the assumption is you are being paid to perform this service. There obviously must be a reason for Nitrogen being specified in this procedure. We use nitrogen in situations where we need to keep contamination from occuring in the items being tested also the size of the molecule in relation to water helps locate the smaller leaks. I have found N2 testing to be cleaner and more accurate. some applications requiring N2 are Breathing Apparatus's / Medical/ Sterile applications. I have also used Helium Trace with Nitrogen because the helium is an even smaller molecule.
"Experience: that most brutal of teachers. but you learn, my God do you learn." - C.S. Lewis
1tech (1); JNB (1); lyn (1); redfred (1)
