Previous in Forum: Transformer Oil Testing   Next in Forum: Earth Fault
10 comments
Remote I/O Connections / Wiring in Switchgear
07/16/2013 8:36 AM
Hi All,
In switchgear world, for analogue signals (Input/Output) from/to contactor feeder / MCCB feeder , we use remote I/O units my understanding is
1- Analogue signals to/from feeder
2- these signal then translate to 4-20mA signal
3- then fed to remote I/O unit (this unit has analogue and digital inputs / outputs)
4- Output like trip/ close the MCCB/ contactor and input like CT/VTs metering etc.
how we do that does the remote I/O card translate the signals to digital to communicate to the control / DCS etc.
I would highly appreciate some links and correction to my understanding above.
cheers
MIK
Re: Remote I/O Connections / Wiring in Switchgear
07/16/2013 8:49 AM
The information is encoded, sent down a data link or network cable, and decoded at the other end.
07/16/2013 8:53 AM
Thanks so the above understanding is correct and need to add encoding process.
07/16/2013 10:12 AM
No need to worry about it. The equipment does it all. All the user has to do is join it all up and configure the I/O. Presumably a full suite of equipment manuals is to hand?
07/16/2013 9:45 AM
What do they teach in schools now?
Nothing worthwhile, I'd guess.
07/16/2013 9:51 AM
Thanks we are on learning curve would appreciate if you experienced Gurus add some more or some links
07/16/2013 10:10 AM
In order to do that, some detailed information of the equipment is use is a prerequisite.
Come to think of it, if that information were available, it could have been in an internet search engine and everything done and dusted by now...
07/16/2013 10:15 AM
Good Answers: 804
07/16/2013 10:21 AM
What ever happened to reading books and studying your assigned task? How about TALKING to potential vendors with good support in YOUR area and explaining to them what you would like to accomplish?
At the risk of contributing to the "dumbing down" of the professional world, here is a place to start.
Begin by studying the term "switchgear", which generally does NOT contain contactors. A contactor is what provides a means of controlling a load, the MCCB is the means of PROTECTING the conductors. You can monitor the STATUS of an MCCB, and you can easily initiate a trip via an external signal, but CLOSING an MCCB remotely is not an easy task. In order to accomplish that, you must affix a motorized operator mechanism, often more expensive than the MCCB itself. Using a DCS to turn small molded case circuit breakers on and off is an extreme overkill in my opinion. Better to use a Motor Control Center or Power Control Center for that, because that implies contactors, and contactors are easy to control.
Secondly, if you have any type of digital control system, such as your DCS or SCADA / PLC system, the addition of analog I/O and transducers to monitor power is cumbersome and expensive compared to all of the options now available from solid state protection and control elements, such as digital MCCBs and Overload Relays. A single network interface appliance (card) in each cubical is now all that is necessary to accomplish full monitoring and control of power. Consider that before launching a new installation into an antiquated system that will be difficult to support in the long run.
In other words, do some research.
Good Answers: 181
07/16/2013 11:05 PM
Thank god I'm retired!
I only have the internet to drive me insane now.
Good Answers: 170
07/18/2013 10:51 AM
Have you not heard of A to D (Analogue to Digital) converters or D to A converters?
Register to Reply 10 comments
electricalexpert65 (1); JRaef (1); lyn (2); mik23 (2); PWSlack (3); TonyS (1)
