Previous in Forum: hooked up with you   Next in Forum: Is Adware Crippling CR4?
Solar / Alternative power.
06/02/2007 6:42 AM
Maybe we need a section for Alternative power?
My solar panels are on a big flat roof which I recently re-surfaced with EPDP (rubber) It gets V hot..how about a cunning (cheap) way to get all this heat into a water supply?
Supplementary Q for those hooked on the solar panel challenge.
I was thinking..if I replaced my hot water cylinder with a 2 coil one, the solar water circuit would be isolated from the central heating. I could then afford to fill it with anti-freeze. Ha, but I'd have the old cylinder...what if I made it into a much more efficient panel (all copper with higher potential water temperature) to replace my notorious 'panel A' ?
You guessed it folks...would the order matter now? (am I going to regret this?!)
Re: Solar / Alternative power.
06/03/2007 11:40 AM
There is a blog on renewables, but I guess you are suggesting one with more technical points.
There are some suppliers of solar tiles - which are fitted instead of standard roofing tiles on sloped roofs (rooves just doesn't look right). On flat surfaces, the collectors would need to be strong enough to cope with foot traffic - 8mmØ copper tube, closely laid?
Parallel!!
Madness is all in the mind
Popular Science - Weaponology - Scapolie, new member.
06/03/2007 2:11 PM
Hi Del the cat. I constructed such a contraption years ago, it is now on the roof of my house giving me all the hot water I need. I placed an utra-thin radiator painted mat black in a wooden case also painted black which was 50mm high on my roof. The radiator was copled to my warm water tank. Then I covered the wooden case with a sheet of glass (very important) as it keeps the heat in and stops air movement within the case. I did this first in 1979 and have now got a larger one one my roof. Spencer.
Hobbies - HAM Radio - New Member Fans of Old Computers - Apple II - New Member Canada - Member - 'ssauga eh?
06/13/2007 10:25 AM
Hmmm, since you already have the photovoltaic you could add an insulated backer to the panels to cool them.
The backer panel would be a thin sheet of metal with some pipes bonded to the back surface. The pipes would lead to an insulated reservoir higher than the panels so you could get away with convection circulation.
As to the antifreeze idea, cheap but dangerous if it can come in contact with domestic water. I would use a light mineral oil that has a higher heat capacity and wont corrode your piping. Bonus would be if you got a leak there is little chance of poisoning.
As a heat exchanger the basic loop of pipe in the preheat tank is simple and cheap. If you can snag one a plate exchanger is much more efficient though expensive if bought new.
there are 10 types of people on this earth. Those who understand Binary and those who do not.
06/13/2007 10:57 AM
I used to hear more about propylene glycol as being much safer than ethylene glycol.
Register to Reply 4 comments
electrone (1); GM1964 (1); Scapolie (1); thrudd (1)
