Previous in Forum: Which Split Type AC Would Be Better: 1 Ton or 1.5 Ton?   Next in Forum: Variable Input Voltage, Constant 12V 5a Supply
Please Help With Flasher Querie
07/18/2013 1:37 AM
Can anyone please tell me where I can access a 36 volt flasher unit for an electric bike. Looks like old unit jong electrical 0579 - 7123359, can not find anything on net. Please help if you can.
Pathfinder Tags: 36 volt flasher uint
Re: Please help with flasher querie
07/18/2013 6:10 AM
A forklift shop can probably help. Lots of them are 36V, with blinkers for backing up.
Good Answers: 73
Re: Please Help With Flasher Querie
07/18/2013 12:40 PM
You could also simply put a 12 volt zenier diode in series with a 24 volt light or two zenier diode in series with a 12 volt flasher. A very simple, low cost solution if you know how to solder and know which way to turn the diode.
A zenier diode has a line indicating polarity. To get it to drop voltage, you have to connect it using "reverse bias". If you use forward bias, it operates like any other diode with only a 0.6 to 0.7 VDC drop across it. That would allow too much voltage to be applied to your flasher circuit.
07/19/2013 4:57 AM
Many thanks for your suggestions, I will try forklift idea first and if unsuccessful the zenier diode,
Thanks Don Moyes
07/19/2013 7:15 PM
A flasher unit means this to me:
36 Volt Turn Signal Flasher Relay
Turn signal flasher relay for 36 Volt electric scooters, bikes, and pocket bikes. Built-in electronic beeper sounds when the turn signals are blinking.
Item # RLY-543
Register to Reply 4 comments
Don Moyes (1); lyn (1); NotUrOrdinaryJoe (1); Tornado (1)
