Previous in Forum: Torque Value   Next in Forum: Ultra High Frequency IGBT Inverter
12 comments
Sensor Question
07/22/2013 12:48 AM
Hi ,
Can any one suggest me some sensor to detect the gap between two part.gap to detect is 3 mm. i have found couple of sensors in internet.but i need some which is small in dimension.approx 15X15X15 mm will be good for my application as location is a big contraint for me.
Thanks for the suggestions.
Re: sensor
07/22/2013 3:15 AM
A £1GBP coin is 3mm thick. If it doesn't go in the gap, the gap is smaller than 3mm. If it does, then the gap is >=3mm.
The coin is 22.5mm in diameter.
[This equipment is used to set-up facing point locks on mechanically-worked points across the UK's heritage railway network.]
Re: sensor
07/22/2013 5:45 AM
That's rather an expensive gague, can't you make one up of smaller denomination coins?
Re: sensor
07/22/2013 6:01 AM
Two 50p coins and some Superglue cyanoacrylate adhesive works just as well, though one cannot spend it afterwards.
Anonymous Poster #2
Re: sensor
07/22/2013 6:26 AM
contraint constraint
Re: sensor
07/22/2013 8:45 AM
Johansson blocks.
Re: Sensor Question
07/22/2013 9:26 AM
Feeler gages. Mount one that is the minimum T and the other at maximum T. Mount them apart and now you have a go/nogo gage.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Re: Sensor Question
07/22/2013 9:31 AM
Re: Sensor Question
07/22/2013 1:10 PM
use optic fiber cable with optic sensor which can place remote location and u can detect small things also
u can try in sick website
Re: Sensor Question
07/23/2013 3:47 AM
Can you describe your process a little bit better?
What are the two parts you're trying to detect the gap between?
What material are the the two parts made from?
Is this some sort of automated assembly machine?
Are the two parts you're trying to detect the gap between, part of this assembly machine or are they part of the product the machine is assembling?
You need to give as much information as possible. Otherwise you'll get all sorts of weird and wonderful suggestions, most of which will be totally irrelevant to what you're trying to acheive.
Re: Sensor Question
07/23/2013 8:03 AM
A wedge gauge?
bioramani
Re: Sensor Question
07/23/2013 8:21 AM
Hello there
Use a linear hall effect sensor and magnet calibrated to the required distance. A readily available PIC board could illuminate an LED if the gap is within tolerance. The sensor will give out a voltage that is related to the distance from a magnet. Note that the voltage is not proportional to distance but to distance squared if I remember correctly.
Peter Jensen
Good Answers: 21
Re: Sensor Question
07/27/2013 6:30 PM
Banner
Anonymous Poster (1); bioramani (1); Dodgy Solenoid (1); fixitorelse (1); loyd (1); lyn (2); Pj3ns3n (1); PWSlack (2); ronclarke (1); user-deleted-1105 (1)
