Previous in Forum: Hydraulic Component Identify   Next in Forum: DM Water Heating
Roll Center of Vehicle
07/22/2013 1:11 AM
what will happen if,front roll center is higher (but lower than CG) and rear i lower than front one ...???
the vehicle is rear wheel drive..
Pathfinder Tags: roll center
Re: roll center of vehicle
07/22/2013 2:25 AM
It will helps you in driving.
07/22/2013 9:02 AM
What is the point of this homework question? It is obviously homework and VERY BASIC.
If you can't answer this question with a little contemplation you do not belong in school.
I doubt that you have figured out turning radius or DVP yet, from your homework questions here last year, so you should work on those first.
Do you understand what CG is?
Register to Reply 2 comments
