Previous in Forum: Water Content In Air Line   Next in Forum: Lube Oil Leak or Bearing Damage?
Boiler Valves
07/25/2013 10:53 AM
Dear all, I am little bit confused about some Boiler globe valves/Angle valves/ Gate Valves constructions.
I have seen that some Steam stop valves have an integrated gland warm-up line DN15 from upstream of the pipe and some valves have gland warm-up line from downstream of valve. In our plant all angle Boiler stop check valves has the integrated gland warm-up line from downstream of valve. Some stop valve has integrated gland warm-up line with an Isolation valve. I understand some steam/Feed water valves has integrated valve By-pass to warm-up downstream pipes prior to open the valve.
I would like to know the function of gland warm-up line with and without isolation valves. In addition to that, I am keen to know the reason for this inconsistency.
Re: Boiler Valves
07/25/2013 11:04 AM
is Google closed today??
Re: Boiler Valves
07/25/2013 12:04 PM
Consult your plant engineering department and they can explain it to you.
If this is a hypothetical question, see #1 above.
Good Answers: 181
Re: Boiler Valves
07/26/2013 7:40 AM
Looking at his previous started topics. It will be a hypothetical question.
Register to Reply 4 comments
Fredski (1); lyn (1); TonyS (1); vladflow (1)
