Previous in Forum: CSA Z662-11 Clause and Clause 4   Next in Forum: Maximum Limit of Torque
8 comments
What Are the Instruments or Thickness Tests to Check LDP?
07/28/2013 4:34 AM
LDPE is used to shrink wrap pallet and thickness is 80,and 140 micron
currently we are using micro meter to check thickness but i have doubt that this is not the right tester to check microns?
Pathfinder Tags: LDPE
Re: Hi.i want to know that what are the instruments or thickness tester to check LDP
07/28/2013 8:10 AM
Have you looked into Alpha thickness gauges?
Good Answers: 109
07/28/2013 11:16 PM
GA JohnDG. Beta Ray monitoring was most commonly used in poly film manufacturing. These units were to monitor most sensitive thickness films like bread wrap or milk bag films. Alarms would sound when an extrusion process slipped. Very accurate systems.
Re: What Are the Instruments or Thickness Tests to Check LDP?
07/28/2013 11:00 AM
If you only knew how to search the internet.
You could type "dry film thickness gauge" into a search engine and have your answer.
07/29/2013 9:54 AM
Or as my friend asked me "Does you computer have a 'g' and a 'o' and a 'l' and an 'e'? -- JHF
07/28/2013 4:00 PM
Ou havre to use micrometer from 50mm to use micrometer100, befor parking mesure ou must check the calibration
07/29/2013 3:29 AM
Do change that keyboard. Some of the keys are not working.
07/29/2013 4:28 AM
I think every second key was missing on that keyboard. It makes me wonder why CR4 has forum posts set up so the poster can preview them before they are submitted, apparently people don't use it.
It is better to have people think you are an idiot, than to open your mouth and remove all doubt.
07/29/2013 9:58 AM
Gibberish.
Register to Reply 8 comments
Anonymous Poster (1); Circuit Breaker (1); haouch (1); JohnDG (1); kevinm (1); lyn (2); techmad (1)
