Previous in Forum: About The Stress Concentration Factor   Next in Forum: Where Can I Find Some Free Websites to Study Bolts and Nuts?
String Test of Pump
07/31/2013 11:15 PM
Hello,
I want to know about the string test of pump. (BFP).
Please share in details and also tell me for the same which code has to be reffred.
Re: String test of Pump
07/31/2013 11:19 PM
No pump.....dump
08/01/2013 1:25 AM
Some Base points:
- GOOGLE is your friend!
- String test
Q -
What is a string test?
A - A string test refers to the testing of the complete pump package, including the
contract driver, baseplate, seal flush system including any oil pots or lube system
for dual seals, and bearing forced-feed lube system, if applicable. A string test
may also include the contract piping, instrumentation, gearbox, or variable-drive, if
specified by the customer.
The vibration acceptance criteria for string test should be negotiated and agreed
upon between the vendor and customer because of difficulty compensating for
factors such as testing on an ungrouted baseplate at the test facility that would be
grouted in the field, or the use of contract vibration monitors that do not allow for
filtered readings at discreet frequencies.
Taken from here
- The code will be the code under which the pumps have to be installed.
08/01/2013 10:59 AM
String test equipment, prior to the test. Best to use biodegradable type equipment.
Good Answers: 203
Re: String Test of Pump
08/13/2013 5:40 PM
BFP is:
Instead of using short nipples use a very long string of pipe, minimum of 67.3 ft. Pipe can vary in diameter (size) from 1/4"pnt to 48"x 0.875" wall. 1/8" not acceptable because it doesn't come in 21' lengths.
Procedure is to connect 20gpm pump to one end with only 2 joints, operate at 10gpm, measure the horizontal distance from the discharge (other) end of the pipe to the horizontal flow at a height of 2' below the discharge end of the pipe (weir angle). The result is the string test. Details available at SPI #1303, chapter 56, section 3.
Good Luck, Old Salt
Register to Reply 4 comments
IdeaSmith (1); lyn (1); old salt (1); SolarEagle (1)
