Previous in Forum: Need Info on All-Geared Lathe   Next in Forum: Liquid Foam
Moisture and Boiler Husk
08/02/2013 6:40 AM
We are running rice husk fired boiler. Often we get rice husk of varying moisture. does any one have ready reckoners to find out impact of moisture on boiler performance ?
Re: Moisture and Boiler Husk
08/02/2013 7:19 AM
You are asking about something you should already have data on, Mate.
08/02/2013 7:52 AM
Sure. The more moisture in the rice husks, the less efficiently they will burn, thus lowering boiler performance.
Sounds like an opportunity to build a large container with an agitator inside, and utilizing the waste heat from the boiler to dry the husks before feeding. If this is a common problem, you could probably sell the units and make some decent money.
08/02/2013 11:22 PM
THANKS TO ONE AND ALL FOR VALUABLE INPUTS
08/02/2013 12:05 PM
Higher moisture content= lower performance.
Pre-dry like kramarat said.
08/02/2013 11:09 PM
Here's a comparison for wood chips.
08/04/2013 7:16 PM
Calorific value is less in proportion to water content. Latent heat of vaporization is an extra loss.
bioramani
Register to Reply 6 comments
Anonymous Poster (1); bioramani (1); kramarat (1); L.Ramamurthy (1); lyn (1); SloopJohnB (1)
