Previous in Forum: Liquid Foam   Next in Forum: Automatic Self-Cleaning Filter Systems
Welding Neck Flange
08/07/2013 7:37 AM
Dear Sir,
I have some question about below description:
1-30 IN FLG A694-F65 WN RTJ CL 900# NACE 28.7MM THK
2-30 IN FLG A694-F65 WN RF CL 600# (ASME B16.47A) NACE 24.2 MM THK
Please let me know in item no. 01 what is the nace 28.7 while the thickness is 12.7 mm (B:9.5 mm)
and what is the nace 24.2 in item 2
Thanks
Arastoo
Re: Welding Neck Flange
08/07/2013 8:06 AM
In (1) the 28.7mm is the flange thickness, the 12.7mm is probably the pipe thickness, and there is no reason they should be equal.
In (2) the 24.2mm is also the flange thickness.
I don't know how NACE relates to these thicknesses, unless something to do with external corrosion. (Or unless NACE means something other than National Association of Corrosion Engineers.)
08/07/2013 10:30 AM
30 - 30" (Inch is a US Customary unit)
28.7mm and 24.2mm are the thickness of the flanges
FLG - Flange
A694-F65 - ASTM A 694 Grade F65
WN - Weld Neck
RTJ - Ring type joint (ie, A metallic ring comes in between both RTJ flange. RTJ flange normally used for high pressure fluid service)
RF - Raised Face (ie, in this case the flange face is little bit raised.most probably a gasket will come in between two flanges during bolting)
CL-900 & CL-600 - It is the pressure class rating of the flanges
B16.47 - ASTM B16.47 standard for large flanges above 24" (ie, NPS 26 through NPS 60).
NACE - National Association of Corrosion Engineers issued lot of standards. The major two are NACE MR 0175 and NACE MR 0103.
NACE MR0175 - It deals with the materials quality requirement used in oil producing environment (ie, oil wells, crude oil transportation pipeline system etc. details available in NACE MR 0175)
NACE MR0103 - It deals with the materials quality requirement used in oil refining environment (ie, details available in NACE MR 0103)
Register to Reply 2 comments
