Previous in Forum: Ergonomics   Next in Forum: Crate Washer Conveyor Gearbox Over Heating
Rail Standards
08/08/2013 6:12 AM
What does rail section 60R refer to??
I am aware of ISCR 60, 60 kg (UIC) rails sectons.
So to which standard does 60R rail section refer to?
One has to watch out for engineers - they begin with the sewing machine and end up with the atomic bomb. - Marcel Pagnol
Re: Rail standards
08/08/2013 8:22 AM
Is this flatbottom or bullhead section?
If it is bullhead, the answer may be found in British Standard 9.
Re: Rail Standards
08/09/2013 12:21 PM
BS11: 1985 (British Standard). 29.882 kg/m. Similar to ASCE standard 60 lb/yd rail but not quite! :-)
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Re: Rail Standards
08/20/2013 8:31 AM
Terraman is rite.
it corresponds to mentioned BS code.
lookin into the weight as per IS 3443, it relates to CR50 (29.8 kg/m)
Varun Passi
Register to Reply 3 comments
PWSlack (1); TerraMan (1); varunpassi (1)
