Previous in Forum: Chemical combustion catalyst capsule   Next in Forum: Acid in Gel form for Stainless Steel Cleaning
9 comments
Oil in Water Separation versus Water in Oil Separation
06/03/2007 1:24 PM
Is there a difference between and oil/water separator (taking oil out of water) and an water/oil separator (takling water out of oil)? Is there a different process involved? Is different equipment required?
Pathfinder Tags: oil separation Water
Re: Oil in Water Separation versus Water in Oil Separation
06/03/2007 10:57 PM
While they would seem to be the same principles, they can be significantly different due to fluid density, viscosity, surface tension, crud collection at interface, wetability of internal surfaces (hydrophobic of hydrofilic), etc. Needs calculation or equipment vendor's expertise
I'm available: http://pqa.net
06/03/2007 11:17 PM
The type of separators referred to are common in the marine industry.
Oil/water separators are tanks that separate the oil by floating to the top, where a censor dumps it into a waste holding tank.
Water/oil separators are spinning vessels (centrifuges), that uses centrifugal force to separate the fluid. A dam or gravity ring is fitted that lets an accumulation of water be discharged. Another option is to pass the mixed fluid into a tank where if has to pass under a dam, whereby the oil remains in the first tank with the heavier water passing under the dam into the adjoining area.
06/03/2007 11:39 PM
Electro Coagulation leaves nothing mixed any more.
Neatest of all technologies.Same simple equipment!
Want practical help? Spell your problem in great detail to mikemahant@hotmail.com
06/04/2007 1:15 AM
I am curious if you do the one then you have the other???
06/04/2007 8:50 AM
The difference is the volume, such as bilges being pumped overboard on a ship, large mounts of water small amount of oil, centrifuges are used for fuel oil, to remove water before using in main engines or boilers.
Popular Science - Weaponology - RaoTR
06/04/2007 2:10 AM
Both are entirely different. They require different equipment. water in oil emuslidon will also require demulsfier chemicals. Electro-cogulation is not the answer as we had tried and failed miserably in some cases. In case of strong water in oil emulsions, you will need heat, a good demulsifier, a centrifuge/hydrocyclone or a simple stabilization by waiting.
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Automotive Engineering - ChemE in a ME world
06/04/2007 11:25 AM
A "Thing" can be "water wet" or "oil wet" and would determine the type of seperation you need. They are different.
No matter how far you have gone down the wrong path....Turn around!
06/04/2007 4:30 PM
Yes, there is a difference. More importantly you need to know the make-up or content of oily-water liquid and obviously your separtion needs/goals.
I recommend a line of products called Beko. I have purchased and installed 3 of these units to clean the waste oil trapped in the "blowdown or condesation disharge. They have outperformed similiar units out currently on the market. FYI... In our application; I'd estimate the oil content to be less than 3% by weight of condensate. The BekoUSA line of products economically & effectively take the oil out of the water.
In my experience, the non-potable water was tested and approved for discharge into the local sewer system. Beko advertises it to be 99.7% clean.
Check out their website: www.bekousa.com
Partner Pat
06/05/2007 5:56 PM
Given what you are asking, the principles are the same, however the application can be highly variable given the type of mixing (ie. free oil, mechanically emulsified and/or chemically emulsified), the volumes and rate of input, and what you want to get out of the separation (quality of oil/quality of water). For commercial applications, gravity separation is most common, ie. a Proceptor Separator. www.greenturtletech.com
Register to Reply 9 comments
Anonymous Poster (5); garth (1); MUKULMAHANT (1); raotr (1); Yani (1)
