Previous in Forum: Electric Motor Liquid Starter   Next in Forum: Battery Chargers Used in the Industry
Good Answers: 170
Isolating Distance
08/10/2013 7:52 AM
As per IEC 60050 (Electrotechnical Vocabulary), for disconnectors (isolators), it is mentioned that "they should meet the safety isolation requirements in open condition". What are these "safety isolation requirements"? How to verify/check the same?
Re: Isolating Distance
08/10/2013 11:57 AM
I think that it is intentionally nebulous, to allow for local codes.
Being a KISS fan, (not the band), I would read that statement to mean: Don't have live wires hanging out, and make sure that the "isolators" are actually "isolating", and not tied into another circuit. In other words, an "isolater" is pretty pointless if it's not doing it's job.
I got bit hard one time by 240 volts...someone thought that a red tag was acting as an isolator, and didn't shut down the damned juice.
Good Answers: 140
08/10/2013 1:20 PM
The required distance between the open contacts is dependent upon the voltage class of the device in question. More than likely that is whet they are referring to. You will have to check the appropriate IEC standard for the isolator to see what the minimum distance must be.
Good Answers: 170
08/11/2013 1:10 PM
I have already referred to the relevant IEC Standards. But, even in IEC 60050-441-14-05, it is only vaguely mentioned that "a disconnector is a "mechanical switching device, which provides, in the open position, an isolating distance in accordance with specified requirements".
I want to know what are the specified requirements of an isolating distance?
08/11/2013 1:40 PM
Here is a free download that might have your answer.
http://www.scribd.com/doc/46465954/GN2-Isolation-Switching
Register to Reply 4 comments
electricalexpert65 (1); kramarat (2); North of 60 (1)
