Previous in Forum: Power Consumption   Next in Forum: Distance Between Two Earth Pits
Calculate Stabilizing Resistor
08/12/2013 9:39 PM
hello engineers, please help me to calculate stabilizing resistor for earth fault relay. as i know,
Rstab = V/I
i know how to find v, but i am confused about I value. whether i use CT secondary current (i.e) 5A or relay setting current. looking for your help..
Good Answers: 19
Re: Calculate Stabilizing Resistor
08/12/2013 10:34 PM
You should take relay setting current. Supposing your CT secondary current is 5 amps and setting value is say 10 %, then you should take 0.5 Amps.
If the CT secondary is 1 amps and setting value is say 40 %, then you should take o.4 amps.
Hope this is clear.
I have developed an APP for calculating the Stabilising voltage and Stabilising resistance. This App will be uploaded to ITunes Stores /App stores shortly
Ramesh,Freelance Electrical/automation Consultant
08/13/2013 8:10 AM
dear sir,
Can u tell that why stabilising resistor to be used in protection relays. is it for voltage drop?
Good Answers: 170
08/15/2013 11:24 AM
Your understanding is grossly incorrect. You may please note that a stabilising resistor is added to an REF Relay circuit, to prevent a mal-operation of the relay for an external earth fault, in case one of the CTs involved in the fault saturates. Under such a condition, the saturated CT would act as a short circuit and would not pump any compensating current to the relay. Whereas, the unsaturated CT in the fault circuit would develop a voltage proportional to the fault current and the design Knee Point Voltage of the CT. This voltage developed by the CT shall not circulate a current so as to operate the relay.
So, the value of the stabilising resistor shall be: {R (total) - R (relay at the setting)}
R (total) = Relay operating voltage at the actual fault current / Relay set current
R (relay) = {VA Burden of the relay at the setting made / (set current)2}
Register to Reply 3 comments
Anonymous Poster (1); electricalexpert65 (1); ramvinod (1)
