Previous in Forum: Emissions Analyzer   Next in Forum: Torque Calculation
BS 5500 (Allowable Stress of Material)
08/23/2013 12:29 AM
I am new to BS5500,
for shell thickness calculation, formula is
e=p Di/2f-p
i have issue with f to find its value
Material: SA 516-70
Design temperature: 212 0F
Design pressure: 265 PSI
Greetings
Engineering problems are under-defined, there are many solutions, good, bad and indifferent. The art is to arrive at a good solution.
Re: BS 5500 ( allowable stress of material)
08/23/2013 12:53 AM
In the U.S., the ASME Boiler and Pressure Vessel Code is followed. Under their method, the allowable stress of SA516-70 is 70,000/4 = 17,500 psi. It appears that BS5500 does this similarly, even if the units are different.
08/23/2013 1:42 AM
f= lesser of [Re(T)/1.5, Rm/2.5]
Re(T)= yield strength at design temperature
take value of Re(T) from ASME sec II part D table Y-1
Rm = yield strength at room temp (20 0c)
for SA 516 Gr 70
Rm=485 MPa
08/23/2013 1:55 AM
That makes sense. Also, my memory of ASME may not be up to date with the current version. The main idea is that there is a safety factor applied; neither ultimate nor yield stress is used by itself.
08/23/2013 2:11 AM
For ASME materials , allowable stress are available against design temperature in ASME sec II pasrt D table 1-A,These allowable stress values are written there by using safety factor 3.5 of tensile strength.
For british code i have no knowledge of such a table so the calculations are to be made for allowabale stress value as mentioned in my last comment.
08/23/2013 2:11 AM
