Previous in Forum: What is the Effect of Humidity on a Compressor?   Next in Forum: Valve Opening Query
11 comments
HVAC for a Hospital
08/24/2013 1:20 PM
Hello everyone, I hope you can help me here, I'm doing this project for a hospital and I have to design the HVAC system for the whole hospital, for the calculation process I'm using Chvac software, in this process I need to give the software the air changes per hour and the minimum cooling supply air that is recommended for each zone I want to use air condition, I'm using the recommendations that ASHRAE gives with this manual: "HVAC DESIGN MANUAL FOR HOSPITALS AND CLINICS" but this manual doesn't give me any information about the gymnasium, I guess it's not common for a hospital to have a gymnasium, so if somebody can tell me where I can find this information, I'd be thankful.
Pathfinder Tags: ASHRAE Gymnasium Hospital HVAC
Re: HVAC for a hospital
08/24/2013 2:08 PM
Thanks for answering that fast, the first link you gave me has some information about what I want but not exactly, I mean, it gives me information about the minimum supply air that is needed in certain zones for a school, unfortunatly it doesn't mention anything about the gym, the other links have general information about HVAC but nothing specific about what I want.
Thanks anyway, I'll take that first link as a reference.
08/24/2013 2:10 PM
There are some many here who know much more about this than I.
Hang around.
08/24/2013 3:28 PM
because....thre isn't really a standard for a gym, trust me
08/24/2013 3:12 PM
School Gymnasium Indoor Air Quality (IAQ) issues examined
Gymnasiums are also considered a place of assembly. Like the other assembly areas, these areas present additional concerns and considerations. ASHRAE 62-1989 recommends a ventilation air rate of 20 CFM per person (based upon 30 people per 1,000 square feet). The primary contaminant in this case is bio-effluents produced by occupants with a high rate of metabolism. Temperature
8 in a gymnasium should be maintained between 65° and 68° F with at least four to six air changes per hour. Minimum air filtration efficiency for these areas should be 30-35% dust spot as defined by ASHRAE Standard 52.1 -1992.
Most gymnasiums are not air-conditioned, although the trend appears headed towards year round use. If air conditioning is applied, Camfil Farr recommends the addition of carbon to
reduce bio-effluents and reduce the required outside air. For optimum performance, three stages of filtration are recommended 30-35% prefiltration, 80-85% secondary filtration and 50% rated efficiency carbon. Outside air may be reduced to 5 CFM per person using this methodology.
Additional consideration must be applied if occupancy increases, based upon the added metabolism and population of spectators for events. Some gymnasiums also serve a dual purpose in some facilities as an auditorium. In this case, outside air or total system CFM must be adjusted to accommodate a five -fold increase in occupancy (30 people per 1,000 square feet to 150 people per 1,000 square feet)."
http://www.filterair.info/articles/article.cfm/ArticleID/A3D776A3-AD38-40F1-A06F01FE6EBF8B54/Page/1
[PDF]Ventilation for Acceptable Indoor Air Quality - ashrae
08/24/2013 4:08 PM
I think this is a recommendation for a normal gym, but in this case, since this is a hospital, people here are patients and they do some exercise for rehabilitation, so we need this area with air condition, and not ventilation.
Thanks for your answer though.
08/24/2013 4:48 PM
You stated specifically that it was a gymnasium, and that it was unusual to have one in a hospital.....Physical therapy is I believe regular stuff in a hospital....and would not be treated any different than general patient areas....You seem to be generally confused...
08/24/2013 5:01 PM
You'r right, I was confused since I had never seen a gym in a hospital, but I don't have much expirience designing HVAC systems for hospitals, so I wasn't sure.
Re: HVAC for a Hospital
08/24/2013 4:36 PM
Guys, thanks for answering, I finally found what I want, I'm using the information that ASHRAE gives for Physical Therapy wihch is almost the same, I'll give you this information just in case someone needs it:
outdoor air changes per hour: 2
minimum cooling supply air (minimum total air changes per hour): 6
now I can complete the calculation of this zone since I already have the information for the area like dimentions of walls, roof, glasses, orientation, equipment, number of people, etc.
Thanks again.
08/25/2013 12:28 AM
I think that in a typical hospital physiotherapy is a part of OPD. It consist of many equipment which look likes Gym. I do not have any idea exclusive gym in a hospital as it is place where people are visiting g for treatment . For ac design of physiotherapy it is similar to OPD areas as described in ASHRAE manual.
08/29/2013 6:03 AM
Consider 20cfm/person OA; 50sqft/person occupancy; heavy work; gyms are ususally crowded during morning & evening hours when ambient conditions are low, hence upto 30cfm OA also gives moderate TR, AHU coil selection is made accordingly for 50-55%RH. In case of hospitals I expect only moderate activity for cardio rehabilitation, physio therapy etc
Register to Reply 11 comments
Fredski (1); GMZ Ahsan (1); lyn (2); mrswamy (1); nicefrog (4); SolarEagle (2)
