Previous in Forum: K Factor for Battey Sizing   Next in Forum: Push Buttons & Hold Contact
Generator Specification Meaning Xd' and Xd"?
09/01/2013 2:56 AM
I want to ask about specs at my Generator i found that text Xd' unsat = 20,7% max and others Xd" sat=11,7% min. could you help me to give clear explanation about this? and what for is that specs. function?
thank you before
Pathfinder Tags: Generator
Good Answers: 42
Re: Generator specification meaning Xd' and Xd"?
09/01/2013 3:16 AM
Julius
Re: Generator Specification Meaning Xd' and Xd"?
09/01/2013 8:27 PM
thank you for your good explaination at this article, but my concern is precentage of this describe what? of generator.?
Good Answers: 38
09/01/2013 8:52 PM
Seems to me to explain the saturation- and the unsaturation percentage of the magnetic coils.
09/30/2013 11:03 AM
Xd' unsat means unsaturated transient synchronous reactance where as Xd"sat means saturated sub_transient synchronous reactance. suffix d represents direct axis values. The statement Xd'unsat = 20.7% max means that for the generator under question should not have unsaturated transient synchronous reactance more than 20.7%. This limit is put to control the transient stability of the generator (P = EVSinδ/Xd'). So higher value of Xd' would reduce value of P. The statement Xd"sat = 11.7% min means that the generator should have minimum 11.7% value of Xd". This minimum value is required to limit the fault current which in turn would control the size of the generator circuit breaker. So maximum values of Xd' unsat and minimum value Xd" sat always form part of generator specification.
10/02/2013 3:51 AM
Thank you for your clear explanation
7anoter4 (1); Epke (1); hariymi (2); pcchatur (1)
