Previous in Forum: How to Convert CSV File of Konica Minolta CR System to Dicom File   Next in Forum: Punchlist
VBA (Excel 2007) Rotating Globe View
09/05/2013 3:35 AM
In excel 2007 I put a world map where each nations can be selected individually. When I click any perticular nation it open a separate map of that nation.
I want to make the view as a globe and the globe rotate. When I click on it, it stop rotating and in second click it again start to rotate. Also, when I click a perticular nation it open the separate sheet as previously.
Please help me how can I do it in VBA Code in excel 2007?
Re: VBA (Excel 2007) Rotating Globe View
09/06/2013 3:26 PM
Sounds like you need some type of timer function to make the image rotate. You can use the not() function to change the state of a boolean to track whether to rotate or not to when the click event occurs. rotate = not(rotate)
09/11/2013 3:47 AM
your intention - sounds to me as beyound the scope for excel - though not impossible
you could attempt to create programmatically (MSO VBA ! using Windows API !) ::
a insertable bitmap object that you may or may not be able to paint with ::
a snapshot of OpenGallery or Active-X "3D scene" <- you also have to create it separately using windows API-s
so i guess its possible but - due the limitations of office/excel it may be too slow/junky for an end user to use it as a real time thingy - although - it might and work
i gess it'd be more realistic to do your thing in JAVA or other web app - or write a separate program for such (you wont have to do the guessing job how to embbed such program in MSO environment)
ci139
09/11/2013 5:11 AM
ups! it's DirectX i gues - however the - "manipulating "directx scene" object "from within" the mso excel" - didn't reveal any results in web search ???
maybe this could be some starting point
ci139
Register to Reply 3 comments
