Previous in Forum: Electrical Power Question   Next in Forum: Generator
14 comments
How to Change Single Phase Motor to Generator
09/05/2013 8:06 AM
Hi I have an electric single phase motor, 4hp/3kw and i want to modify it into single phase generator. It is 1400 rpm as speed, it has 2 capacitors, 450VAC and 350VAC. Is it possible to change it?
Re: to change single phase motor to generator
09/05/2013 8:36 AM
Well, in order to do that, one would need to sort out where the magnetic field needed to make it generate is going to come from. Any thoughts on that?
Re: How to Change Single Phase Motor to Generator
09/05/2013 8:55 AM
In lieu of 20 questions:
OPERATING 60 CYCLE INDUCTION MOTORS AS GENERATORS .
You obviously did no research before coming here or your would have been presented with About 5,450,000 results (0.29 seconds)
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
09/05/2013 9:13 AM
Or to answer the OPs question directly:
Yes.
There, wasn't that good?
09/05/2013 9:29 AM
09/05/2013 9:31 AM
Yes, but you used 11 too many words.
09/05/2013 10:49 AM
Thank u, but before thinking about forum is that i try to use this document and do not match.if u succefully do that and it works, plz give me a whole procedure. Thank you
09/05/2013 10:54 AM
Did you look at any of the other sites to see if you can understand any of them?
If no, do some more research. If yes, which ones do you not understand.
We don't have any meaningful information to work with. You have all that.
09/05/2013 11:09 AM
I can not see how to send to a picture! I tried to applicate what i readed and i get nothing. First of all, did u do that or u are trying to help only in theory?
09/05/2013 5:14 PM
Manufacturer's name?
Model # of motor?
Name plate information?
Even color of motor might give us a clue.
09/05/2013 10:59 AM
Thx to the forum member. I tried avery thing you are telling me exept one for replacing or placing permanent magnetic material. If u succed to do this, give me a procedure. Thx
09/05/2013 11:20 AM
Why, if it's commercially sensitive information?
09/05/2013 11:28 AM
Commercially sensitive to whom?
09/05/2013 3:32 PM
That tickles, stop.
Good Answers: 181
09/05/2013 9:47 PM
No doubt there will be lots of e-mails heading your way. Not ones you want though.
Don't publish your mail address!
dieudonne (3); JCase (1); lyn (4); PWSlack (3); redfred (1); tcmtech (1); TonyS (1)
