Previous in Forum: Brinell Hardness of Steel   Next in Forum: Steam Water Cyclone Separator
Join PVC to Transite Pipe
09/07/2013 8:58 AM
What is the best way to join pvc irrigation pipe (1.5") to 4" transite pipe?
Re: Join PVC to Transite Pipe
09/07/2013 10:39 AM
  • Use plastic pipe reducer, available at your hardware store.
Good Answers: 203
09/07/2013 11:10 PM
FERNCO rubber and St. Stl. clamped fittings. Available in reducing couplings, bushings, couplings, elbows, sweep elbows, 90 deg elbows, 45 deg tees, and many others. Easy to use.
Answer to OP question is: 2" x 1-1/2" Fernco bushing and a 4" x 2" reducing coupling. Put the 4" end of the reducing coupling on the transite pipe and tighten clamp. Push 2" x 1-1/2" bushing into the 2" coupling end and tighten clamp. You now have a 4" x 1-1/2" coupling.
One piece units available from factory.
Good Luck, Old Salt
