Previous in Forum: Stiffener Ring   Next in Forum: Pressure Vessel
10 comments
Chatter Mark on Bore Inside
09/13/2013 6:56 AM
Dear sir ,
I am using on spm machine .process for fine boring on single spindle .
bore size 93.6 mm
bore length - 180 mm ,
I st cut - 1 mm,
2 nd cut - 0.5 mm
tool carbide insert
running speed - 400rpm
hydraulic feed is 0.2 mm
we are getting on chatter marks inside the bore in above process .
how to rectify problem ?
Pathfinder Tags: ..
Re: chatter mark on bore inside
09/13/2013 7:08 AM
Either make the tool-holder stiffer, or make shallower cuts, or reduce the feed rate, or some combination of them.?
Re: Chatter Mark on Bore Inside
09/13/2013 10:45 AM
Also, be sure that the insert is correct for the material/cutting rate.
An insert for roughing may chatter on a finish cut.
You can try an insert with a larger nose radius as that puts more pressure on the tool which may relieve the chattering.
Sometimes I have had good results by cutting on the back stroke when taking a fine cut like that.
On the other hand, you may need to back off and take a larger finish cut to keep the tool from bouncing around.
Try another cutting fluid.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
09/13/2013 7:27 PM
It might help to know what material you are trying to run, and the actual feed rate.
Depth of cut may be an issue, but not knowing the material renders all opinions moot.
Good Answers: 42
09/14/2013 1:28 AM
You gave no description of the part being machined, size of machine, material being cut etc.
I have sometimes eliminated chatter by actually cutting much faster. Chatter is partially a resonant phenomenon, along with metal properties.
Keeping the tooling and supports rigid always seems to help.
09/14/2013 6:11 AM
Presently working for a weapons factory, I have known the speed of the drill in rpm's has an effect. The first thing I would do is increase the speed of the drill at least 5 times. The drills at my company has drill speeds in excess of 10,000 rpm.
09/15/2013 8:26 PM
Need more info. A sketch or photo of part and how it is held would greatly help.
09/16/2013 12:30 AM
Hi
1. Vary the revs you might not have the right cutting speed but you will get away from the resonance (you might have to go slow to get under the chatter and then increase for finish).
2. Change the length and or increase the diameter of the boring bar (can you provide another support for the bar eg a backing strap) You can also clamp mass of the bar to absorb vibrations, also a rubbing block attached to the bar will change the amplitude.
3. Change cutting compound
4. Change the tip material, rake and radius (smaller will take less resistance and may overcome chatter)
5. Try a heavier finishing cut and increase/decrease feed (will stop the tip from springing)
These are not in actual order (depending on how much material you have left) try what is the easiest first step
09/16/2013 9:50 AM
Looks like another waste of our time on someone who doesn't have the courtesy to respond to the help offered.
09/16/2013 10:01 AM
Depending on the material you are cutting the speed may be correct. If the feed is .2mm per minute, I am guessing, then the feed rate is way too slow. If you are using a coated insert the hone on the cutting edge is likely to be greater than the feed. When the feed is less than the hone then you are not cutting, you are pushing the metal which creates alot more pressure. I would try a higher feed rate.
It is not a mistake if you learn something from it.
India - Member - New Member
12/04/2013 12:07 AM
You need to have a sturdy boring bar with the right length. Try to manufacture a boring bar with slight taper towards the cutting tip. Make sure that the hydraulic feed is smooth and and does not work intermittently.
Register to Reply 10 comments
evaluator (1); Govind Rao (1); GW (1); Harvey Patterson (1); lyn (2); Master of Naught (1); Mike W (1); Munster (1); PWSlack (1)
