Previous in Forum: CCTV   Next in Forum: 750 KVA TWO 11/.415 kV Transformer
D.G. Set Auto Start & Auto Synch
09/14/2013 11:47 PM
my three D.G sets 625,500,500 KVA , .i want run auto start and sych.Presently independent run mode.my present running load 800 KVA.so kindly suggest me.
Good Answers: 141
Re: D.G set auto start & auto synch.
09/14/2013 11:50 PM
What is D.G. and also sych?
Plenty of room here
09/15/2013 1:06 AM
You desperately need some courses in electrical theory.
Perhaps you should hire a technician who can educate you as he straightens out your power plant.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
09/15/2013 5:40 AM
do they all have the same control panel? is it sync-able? what make/model is the control panel?
BSEE but always learning
09/15/2013 9:10 AM
This gives synchronization and auto load sharing sequence....
http://elemech.com.pk/sync.html
Good Answers: 170
09/15/2013 9:27 AM
Search the net; there are plenty of compact electronic modules available for auto start & auto synch. of DG sets.
Good Answers: 181
Re: D.G. Set Auto Start & Auto Synch
09/15/2013 11:39 PM
Having read this guys past questions it begs the question.
"Who in their right mind would let him near a generator!"
Good Answers: 116
09/16/2013 1:42 PM
You say sets "independent run" mode at present.
Consequently, there is no guarantee [to us remote onlookers, who do not have all - seeing power] that governors and AVR are currently capable to run in parallel with other generators.
Speed (governor) and reactive power (AVR) "droop" [fall of speed or voltage with increasing load of several % rated between zero and rated load] are the minimum requirement for parallel running. Reactive power droop usually needs a CT (current transformer) input to the AVR as well as generator voltage.
You need to have parallel-run capability before you get to auto start and synchronise.
As is now, can you parallel the units under manual control??
67model
Register to Reply 7 comments
1capybara (1); 67model (1); dvmdsc (1); electricalexpert65 (1); lyn (1); SolarEagle (1); TonyS (1)
