Previous in Forum: Selective Breeding Of Super Cows   Next in Forum: High Voltage Inductive Load Switching with MOSFET
12 comments
Pond Guy
09/19/2013 1:16 PM
I need info on fluid flow at varying distances. I am building a gravel filter for my pond and need to know what size of holes to drill in the drain matrix to balance the flow to the pump at any given depth and size of pump. I am not an engineer and need information that a layman can understand. Thank you
Pathfinder Tags: filter flow hydraulics pond
Re: Pond Guy
09/19/2013 1:23 PM
Not sure exactly what, " balance the flow to the pump at any given depth and size of pump" means. Start here↓
How To Build The Sand and Gravel Pond Filter. - YouTube
DIY Pond Filtration System Best Pond Gravel Filter Design. - YouTube
Re: Pond Guy
09/19/2013 1:35 PM
If I have a 5000 GPH pump and 20 feet of 2 inch pipe collecting water from a pond at 6 feet deep don't I need to drill varying sizes of holes in that pipe to draw the water evenly thru each hole?
Thank You for the Suggestions
Re: Pond Guy
09/19/2013 2:27 PM
Oh, now I get it.
Single horizontal pipe at 6' depth, suction at one end.
Yes, probably is some formula, but it isn't in this brain. I'll have to look at that.
Maybe some of the larger brains here can give you some help.
Still not sure that a single opening at the lowest point won't work as well. Depend on the gradiant of the water and what you are trying to filter.
My pool pump sucks from the lowest point and the skimmer equally.
Re: Pond Guy
09/19/2013 4:04 PM
thank you
Good Answers: 104
Re: Pond Guy
09/19/2013 2:41 PM
I don't know anything about gravel filters, but if you can describe (or give a link to) what you want to do, someone can probably help. But I can tell you 5000 GPH (80+ GPM) is too much for a 2" pipe.
Good Answers: 125
Re: Pond Guy
09/19/2013 3:58 PM
I am assuming that you meant 500 GPH. At 5000 GPH your pipe would probably collapse.
Multiple holes in the pipe for suction will minimize the disturbance of pond sediment. I assume that is why you are doing this.
Drill 64 holes of 1/4" at regular intervals along and around the pipe, and cap the end. The combined area of these holes will match the 2" outlet in terms of area. Each hole will take in 0.13 GPM, which should be adequately reduced velocity.
Re: Pond Guy
09/20/2013 6:02 PM
I'd go down to 64, 3/16" dia. holes so the tube will act as a plunum and distribute the suction over the entire distance.
Assuming that 6 foot depth of the pipe is not too close to the bottom of the pond.
Good Answers: 125
Re: Pond Guy
09/21/2013 12:25 AM
You are right that suction will be more evenly distributed, but velocity will be increased.
Re: Pond Guy
09/21/2013 12:41 AM
Velocity through the holes, OK, but velocity inside the horizontal and riser section? Turbulance will be settled as the stream makes the turn at the elbow and traverses up the verticle pipe, at lower velocity.
The pump won't care, will it?
I'll be going to bed now.
Re: Pond Guy
09/19/2013 9:51 PM
sounds like a water propelled rocket
Re: Pond Guy
09/19/2013 9:59 PM
trial and error, start small then work you way up.You will find a pattern as you increase size or number of holes, this will give you a fair indication on you target.
Re: Pond Guy
09/20/2013 5:33 PM
In other words we don't know either!
Register to Reply 12 comments
bigg (1); eltech (1); Fredski (1); G SAVILLE (2); jmart23 (1); lyn (4); WJMFIRE (2)
