Previous in Forum: Same WPS & WPQR Can Be Used for Butt & Fillet Welding?   Next in Forum: Looking for Hydraulic Valve with Manual Reset for Intrinsic Safe Loop
12 comments
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Initial Unbalance in Die Cast Rotor of Induction Motor
09/21/2013 12:22 AM
Hi,
We are working on Limiting the Initial Unbalance of Die Cast Rotors of Induction Motors.
Can anybody help me by suggesting any Standard for restricting the Initial Unbalance of Die Cast Rotors.
Initial Unbalance is the Unbalance in Rotor before Balancing Correction.
Regards,
Vishram Lele
Re: Initial Unbalance in Die Cast Rotor of Induction Motor
09/21/2013 12:32 AM
It is difficult to suggest solutions to an undefined problem.
It's like asking how to make a good cup of coffee without knowing how you are doing it now.
I'd suggest the expenditure of money to hire someone who can observe the present processes and conditions and recommend a solution, if there is one.
Perfection costs money and cannot be gained from an anonymous forum with nothing with which to work.
Break loose with a buck and hire a consultant.
An internet search might help: Die Casting Process, Defects, Design
09/21/2013 4:41 AM
I don't think there is a standard per se, but certainly a reasonable expectation....Here is a discussion (linked) that covers pretty much all that's involved....
http://www.linkedin.com/groups/Intial-unbalance-in-DieCast-rotors-1833849.S.186934716
Good Answers: 27
09/21/2013 8:55 AM
Implementation of good engineering design and manufacturing practices coupled with a decent quality control on raw pre-production material selections will solve most of your issues /problems.
No known published standards!
Good luck with your search
vsar
09/21/2013 10:20 AM
Do the casting in outer space, where there is no gravity.
Good Answers: 88
09/21/2013 5:20 PM
You can try to determine what is causing the imbalance. imperfections on dimensions of the laminated core, its centering, its channels etc, Al conductor casting air pockets, or some offset of outer connecting AL rings (I obviously assume you use Al conductor, the mainstream material for induction core rotors). There's no rule that says where a problem will happen, it depends on what specific compromises you had to make to keep cost down. S.M.
09/21/2013 11:04 PM
If a 50Hz rotor is operated on 60Hz supply(to stator)will there be unbalance?.
pnaban
09/21/2013 11:42 PM
No. It will turn more slowly is all.
Good Answers: 117
09/22/2013 7:54 AM
As you increase the RPM, which is related to the supply Hz, the vibration will increase with speed. If its unbalanced at 50Hz then its STILL unbalanced at 60Hz, the only difference is the vibrations increases with speed.
09/25/2013 10:36 PM
Due to bad form factor of applied voltage wave, due to harmonics,-ve sequence component etc will unbalance,in addition to vibration result?.
pnaban
Good Answers: 117
09/22/2013 7:51 AM
I think its a simple case of..you know about it, so do something in your pre-production to get rid of the problem!
I would start with your pattern/model maker, then look at the material you are using in the casing process, and your casting process. Maybe you are not removing ALL the air out of the mould as you cast.
Also you must remember that no cast will be truly balanced, so you will have to balance it. Something that many manufacturers forget or don't realise they have to do
If not the results of a non-balanced rotor can be severe. I was commissioning a 500HP 3.3Kv motor, and once we were satisfied that it was alined and no soft foot, we started it up. The vibration was off the scale. The motor was removed and the rotor checked, found to be out of balance, then balanced.. once assembled and fitted it run with almost zero vibration.
So if you know about, do your best to get rid of it!
Standards for this..... not sure, but common sense and the drive to deliver a good product should be your guide.
09/22/2013 11:29 PM
Dear All,
Thank you very much for your valuable suggestions.
Yes, we are looking in the process of Die casting in depth to get the clue of the High Initial Unbalance.
The purpose of this post is to understand if any standard / thumb rule available which can tell us the limits of Initial unbalance.
During the process of balancing this initial unbalance will be corrected to G2.5 (ISO 1940-1), but our efforts are to limit this initial unbalance.
Thanks a lot again.
Regards,
Vishram Lele
09/23/2013 3:26 AM
ISO 1940 is the standard used for balancing of rotors whether old or new. Although it is an old standard, it is still very much used.
Register to Reply 12 comments
brich (2); Deefburger (1); IRSHAD (1); lyn (2); pnaban (2); SimpleMind (1); SolarEagle (1); vishram lele (1); vsar (1)
