Previous in Forum: Why Does My Spelling Errors File Not Work?   Next in Forum: Which Program Should I Use?
Toggle "STAR" to "DELTA" in Command Button Using VBA
09/23/2013 5:10 AM
In Excel 2007 I make an application using VBA.
I place a command button along with a combobox. The caption of the command button shows " STAR " when the userform2 open and the combobox appear at that time. Now, if I click on the command button then it changes to "DELTA" and combobox disappear.
Now, if I again click on the command button then "STAR" and comboboxnot appear.
Please help me how I can do it.
Re: Toggle "STAR" to "DELTA" in command button using VBA
09/23/2013 7:29 AM
FactoryTalk 32 would be a better platform for doing this sort of thing than Excel.
Change the package.
Good Answers: 38
Re: Toggle "STAR" to "DELTA" in Command Button Using VBA
09/23/2013 9:23 PM
There is something wrong with your code, post or as on a programming forum.
(check in the code of the button if the appropriate functions are called)
Good Answers: 122
09/24/2013 8:56 AM
Invoke debugger and watch the code algorithms execute then correct the error.
If you cannot understand it, post the algoritms and someone can help you.
09/25/2013 7:00 AM
My VBA Code is:
Initially CommandButton1.caption="STAR"
Private Sub CommandButton1_Click()
If CommandButton1.Caption="STAR" then
CommandButton1.Caption="DELTA"
ComboBox1.visible=False
End if
If CommandButton1.Caption="DELTA" then
ComboBox1.visible=TRUE
End if
End Sub
Good Answers: 38
09/25/2013 8:57 PM
Is this the copied code?
I always use these "{" after an if
In C++
if (test)
blalalala
I don't know VBA but in C++ without brackets only the line after the if statement is checked, also True or TRUE?
Also seeing this code the box caption should not change (or only briefly) because in the next if statement it would change it right back.
09/26/2013 1:28 AM
I solve the problem.
thanks
07/24/2017 4:53 PM
You should try using elseif in the middle part of the code instead of end if.
Elseif CommandButton1.Caption="DELTA" then
Register to Reply 7 comments
amitabha0107 (2); Epke (2); PWSlack (1); SHOCKHISCAN (1); terrapin (1)
