Previous in Forum: Term Schedule Used in Pipe Nomenclature   Next in Forum: Simple Motor Control Application?
10 comments
India - Member - New Member
Welding Pipe and Galvanizing Issues
06/05/2007 9:54 AM
hi,
Will you help to guide me with your idea? Situation-ERW pipe with coupler joint to be embeded in a cement segment (bridge). Requirement is to galvanize the whole job,but the problem is if we galvanize after welding pipe and coupler that the thread gets zinc coated and would be difficult to screw/unscrew the coupler. Can you suggest a solution for me? Galvanizing to be done after final welding.
looking forward for your response
With Regards
Re: Welding Pipe and Galvanizing Issues
06/06/2007 3:15 AM
Hi,
Is it a water supply or sewer pipe? is it possible to use heavy duty PVC pipe in this part of the job? then by using flanges change it to galvanized pipe.
Good luck
Never laugh at anyone's dream. People who don't have dreams don't have much.
06/06/2007 10:42 AM
hi,
Thanks for reading,These pipe are fabricated as guide pipe through which 100 dia cable is to be pass.these cables hold the 150mt segment to the main pilon at center.to prevent corrosion in sea condition it is to be galvanised.I think i made my point
Looking forward for your rresponse
with regards.
06/06/2007 9:43 AM
please can you say the size of pipe
06/06/2007 10:36 AM
hi,
Thanks for reading.the size of pipe is Od-273,8thk and it is to be embeded in concrete(In concrete segment).to prevent rusting and corrosion in sea condition it is suggested to galvanize.
looking for your response.
With regards
06/07/2007 12:05 AM
galvanizing of any MS metals including the threaded area is very less and thickness of coating is in microns only. ( hardly 0.50 kg per sq. meter) Hence should not pose any problem while coupling it. In fact most of the bolts / nuts are either zinc coated, cadmium or nickel coated. U an go ahed with welding and coat it later also.
sridhar
06/07/2007 2:14 AM
hi shridhar,
thanks for your response.looking forward for your future assistence.
with regards.
06/07/2007 11:25 AM
If it is to be used as a cable duct, would plastic be a better proposition?
Good Answers: 16
06/07/2007 12:00 AM
My experience in Power Stations is that we tried to avoid using metal pipes immersed in concrete. In older power stations they used segmented clay pipe to run cable in. It doesn't corrode and is relatively easy to draw an electrical power cable through. The modern power stations in Australia use a plastic pipe. This has no corrosion problem and is even easier to draw the cable through.
It may be that in India it could be possible to have a potter make the short lengths (approximately 1 metre) of clay pipe so that one end will fit inside the tail end of the last pipe. If a water tight joint is needed it can be sealed with concrete, rubber O rings or silicon sealant.
Galvanised pipe in a salt water environment has a limited life or will require lots maintenance in the form cleaning and painting to protect it.
Make it so.
06/07/2007 1:33 AM
For mild steel welded piping system, required to be galvanized after welding, I prefer to use flanged connections that easly assembled after welding and galvanizing. A lot of projects had been designed by that procedure like as fire fighting systems, cooling circuits, ... etc.
Fans of Old Computers - Vector 1 - New Member
06/07/2007 4:41 PM
I have used this method many times with great success. We always power brush the coupling connections or if possible tap or die may be used depending on your specific application.
Mark
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." Mark Twain
Register to Reply 10 comments
Abdel Halim Galala (1); Anonymous Poster (2); BlueAussieBoy (1); BRANSON (1); Hamid K Saberi (1); PWSlack (1); shaffimj (3)
