Previous in Forum: Digital Control Valve   Next in Forum: Blowdown Valve Failure
12 comments
Low Flow Switch Recommendations
09/26/2013 12:51 PM
recently I have been having issues with magnetrol TD1 flow switch to monitor low flow rate of our water Injection system. I am looking to replace the flow swtich with a different Model. I dont want to use a kayden as I have had issues with them. So I thought id throw it out to some of the experts and get some different opions.
Thanks
Pathfinder Tags: Flow Switch
Re: Low Flow Switch Recommendations
09/26/2013 1:52 PM
Did you look here?
09/26/2013 2:06 PM
I hear Flo Boss 107 works well.
09/26/2013 2:11 PM
Is that the gal in the Progressive commercials?
(from here)
09/26/2013 2:24 PM
More like "go with the ....."
These flowy things can be daunting to newcomers to them.
The instructions that come with them are written for experienced instrumentation techs.
I had the same problem, once, then hired a good tech and all my worries were over.
PWSlack might suggest ringing up the vendor for some help.
09/26/2013 2:37 PM
I've dealt with many flow meters myself, with many different rates of many different media. I've measured liquid and gaseous Helium flow rates, Argon, cooling water, at flow rates of mL/min to L/sec. I've used ultrasonic, paddle wheel, thermal cooling and pressure differential calibrated orifice measurement techniques. One persons idea of a low flow rate is another's idea of a torrent. If the OP doesn't wish to give us any information, they should go looking for themselves.
09/26/2013 2:51 PM
I was in the fortunate position of just hiring people to do the real work.
We might have 20-30 flowmeters/ORP/conductivity meters etc. running dosing pumps and process equipment and 50 pumps and heaters through PLC or DCS on a 75 foot process line.
It was too much for my pea brain. They just let me play with the touch screens when the line was finished.
09/26/2013 3:52 PM
Perish the thought...
09/26/2013 2:29 PM
Ha Ha I believe you are being facetious.
09/26/2013 2:17 PM
It also depends on how critical the flow rate is for the patient. There are many methods out there.
Eschew obfuscation.
09/26/2013 2:35 PM
Yes I am well aware of the several different choices. I am looking for a proven switch that does not give false trips.
09/26/2013 3:58 PM
Any instrument when abused or attempting to operate outside of the designed parameters will give false information.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
09/27/2013 10:15 AM
If the application is critical enough, you might wish to consider using an actual flow *meter* (i.e. an instrument with a scaled rather than discrete "on/off" register of flow) rather than just a flow switch. A flowmeter's continuous measurement can reveal problems long before they become serious, whereas a discrete switch can fail "silently".
A really simple and relatively cheap example of a flowmeter would be a Dwyer "Photohelic" (or equivalent) low-pressure differential gauge/switch connected across an orifice installed in the pipe. The switch function provides the low-flow alert you need for the application, while the analog display of the gauge allows a technician to do simple qualitative and quantitative assessments of its operation.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 12 comments
lyn (3); Macgyver71 (2); PWSlack (1); redfred (5); tonykuphaldt (1)
