Previous in Forum: Minimum Insulation Resistance   Next in Forum: How to Find Neutral Current of Unbalanced Transformer
Need References and Sources for Wind, PV Along with Diesel Backup Hybrid System
09/29/2013 12:13 PM
Hi all,
I'm preparing a seminar report on Hybrid Power Systems (Wind,PV along with Diesel Backup). I would be really thankful if members would suggest me some good references and sources to avail content from.
Thank You
Pathfinder Tags: Hybrid Power Systems
Re: Need references and sources for Wind,PV along with Diesel Backup Hybrid System
09/29/2013 12:23 PM
The internet is a good resource for your research.
We don't do homework here.
Tips for Posting on CR4:
  • Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
  • Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
09/30/2013 7:58 AM
@Lyn, I've searched down Google and I've a number of sources at me. Still I joined this forum to get some valuable suggestions/posts on topic I'm looking for from some wise and knowledgeable people if I can.
Thanks,
Manas
Thank You
09/30/2013 9:22 AM
Perhaps some wise and knowledgeable people will do the research for you.
You may have joined this forum for the wrong reason, since it seems that you are unwilling, or not able, to do basic research and glean information from the resources available.
Perhaps you should hone your searching skills and try again.
How to Search the Internet - Southern Oregon University
Almost everything ever written is available on the internet, good luck.
09/29/2013 1:28 PM
Im thinking Google for 8 hours
Re: Need References and Sources for Wind, PV Along with Diesel Backup Hybrid System
09/30/2013 10:44 AM
In 1960s British firm Hawker Siddley did it.
pnaban
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
09/30/2013 10:49 AM
wikipedia is your friend and lists lots of sources for what u need
BSEE but always learning
Register to Reply 6 comments
1capybara (1); Fredski (1); lyn (2); ManasMIT (1); pnaban (1)
