I work for Eskom Electricity Utility in South Africa. We experience oil leaks on most of our distribution transformers. The leaks are on the gasket between the transformer tank and the bushings. The seals wear and tear over time. I know that there are oil leaks arrest putties and sticks to mitigate the oil leaks. I have questions with regards to the leak arrests:
i. What is the success rate
of transformer oil leak arrestor
ii. The transformer seals (rubber material) can wear and tear when they come into contact with water and exposure to sunlight. Are the oil leak arrestors (e.g. putties & sticks) immune to the environmental effects?
Poor workmanship can contribute to the oil leaks on the gasket between the transformer tank and bushings. Are there any other mitigating measures to transformer oil leaks.
Your assistance will be highly appreciated.
Kind Regards
Thabiso Kgosiemang
CR4 Admin -
email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will
delete all phone numbers and email addresses posted in threads or comments. You
can share this information via the CR4 internal messaging
system.
