Dear colleagues,
I have the values for a magnet used in a permanent magnet generator and it is stated that maximum temperature is 140ºC, which I believe is the Curie temperature. Also it is stated that minimum Br is 1.40T. So, these are the values for the intrinsic curve, isnt it?
The temperature at rated load is calculated at 75ºC and Br is 1.20T.
As far as I have seen in all the normal curves, as far as you increase the temperature you decrease the value of remanent flux density. So, according that... shouldnt Br(1.20T) for 75ºC be higher than Br(1.40T) from 140ºC?
I am pretty sure that I am making a mess... but dont find why...
Thank you very much for your help,
Best regards,
Jorge
