Previous in Forum: Demagnetization of Permanent Magnets   Next in Forum: Liquid Resistance Soft Starter
SSR with Double Change Over
10/10/2013 3:48 PM
Dear Friends,
I am in search of double change over Solid State Relay. Is it available anywhere?
Actually, at present in my system, there is a FINDER make miniature relay is used , contacts of which fails frequetly and that I want some other solution.
SSR is one of the best option , but SSR is available only with single chage over contacts as per my knowledge.
If u r having any other solution, pl. share.
Thanks
Pathfinder Tags: SSR
Re: SSR with doble change over
10/10/2013 3:55 PM
Try to do some work on your own, first.
That will reduce your dependence on total strangers who have no incentive to help you.
GlobalSpec Electronics
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Re: SSR with double change over
10/10/2013 5:03 PM
Yes it is available in several places. Being in India, I would imagine you would like to search at your local supplier first.
It is better to fail in originality than to succeed in imitation.
Re: SSR with Double Change Over
10/10/2013 11:17 PM
Ignore Lyn, he has a bad back. What current and voltages will be needed? Perhaps one of these will work: http://www.globalspec.com/search/products?page=mi#comp=1083&vid=98455&sqid=4586462
10/11/2013 12:20 PM
Thanks Mr. SSCpal
in present system coil voltage is 24 VDC, NO/NC contact rating should be 5A
Thanks
10/11/2013 12:24 PM
I just realized the units I noted are SPDT and I think you want DPDT. You could always use 2 SPDT units in parallel to do the job.
dhanesh.koshti (1); Economist (1); lyn (1); SSCpal (2)
