Previous in Forum: SMC Plus Burnt Components   Next in Forum: TSOP IC in Proteus Professional
8 comments
Couldn't Identify SMD Code
10/10/2013 2:57 PM
Hi,
I have a circuit which is textile mills, and in this circuit a semicinductop is installed by the manufacturer. It looks like BC846 SMD (code 1b) or BC856 SMD (code 3b) but it is not transistor. I have searched by internet but did not find this code, and unfortunately I don't have a diagram. Can anybody help me to find this components which has code S2E? It is three pin components.
I will be very thankful.
Munawer Hussain
Oct 10, 2013
Pathfinder Tags: SMD
Re: Could't Identify SMD Code
10/10/2013 3:39 PM
http://datasheetcatalog.com/datasheets_pdf/B/C/8/4/BC846.shtml
found at top of list in search for bc846.
I have no idea what you do to search, but it is obviously not getting you where you need to go. ? could it be internet restrictions where you are located, perhaps you are being blocked.
post again if that link does not work
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
10/10/2013 5:04 PM
NPN Silicon AF Transistors. Why would that be blocked?
It is better to fail in originality than to succeed in imitation.
10/10/2013 5:09 PM
Grasping at straws, giving benefit of doubt. could be site and not item specific. I dont really care. it was found.
Re: Couldn't Identify SMD Code
10/11/2013 6:11 AM
What is a Semicinductop?
10/11/2013 7:28 AM
semi = half.
cin = sin, misspelled.
duc = what ductape is used on
top = opposite of bottom
semi-cin-duc-top = upper portion of an evil duc.
10/11/2013 10:53 AM
That's what my cat thought.
Originally he thought he was going to stalk our mallards, but the drake wasted no time showing kitty he wasn't going to play his game.
10/11/2013 8:16 AM
This is all I can find:-
Siemens SMBTA93 high voltage PNP transistor
Data sheet
Why don't you think it's a transistor?
There is also a Toshiba TPC6005 FET but it's a 6 pin device
10/28/2013 11:29 AM
When others offer almost immediate help, it would be nice of you to come back and say thanks.
Register to Reply 8 comments
Brave Sir Robin (1); DRFREON (1); Economist (1); LongintheTooth (3); Passerby (1); Randall (1)
