Previous in Forum: Couldn't Identify SMD Code   Next in Forum: How To Capture The Data Following Via RS232 in ASCII Format.
TSOP IC in Proteus Professional
10/11/2013 7:44 AM
How to use TSOP 1736 IC (infrared receiver) in Proteus professional software. I searched in the library but could not get it. Under what name it is available in the library?
Pathfinder Tags: Proteus professional TSOP
Re: TSOP IC in proteus professional
10/11/2013 8:20 AM
if you can provide the other letters in the part number you can type the number in the search bar and get a pdf data sheet. Is it too new to be in the library ?
10/11/2013 8:24 AM
Problably not in the library. May be lucky and get it from a 3rd party or you may have to create your own model. Look here - <click>
Re: TSOP IC in Proteus Professional
10/11/2013 11:03 PM
Very misleading part name. There are surface mount device packages with the TSOP (Thin Small-Outline Package) designation.
You are right, it isn't in the Proteus library. I suggest reviewing the TSOT1736 (no space - most electronic component part numbers do not have a space between the letter prefix and the number suffix) Datasheet and then checking the Proteus Help files for how to make a custom component/device. If you can't find it, call Proteus and ask them how to do it.
Pretty new to electronic design?
Register to Reply 3 comments
JohnDG (1); LongintheTooth (1); Mikerho (1)
