Previous in Forum: Can A 2-Cycle Engine Be Made to Run Off Steam?   Next in Forum: Reduce Natural Convection
24 comments
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
How to Increase Heat Transfer/Reduce Contact Resistance
10/15/2013 6:48 PM
Any suggestions on how to increase heat transfer /reduce contact resistance between two mating surfaces. Both are flat and bolted together.
It is better to fail in originality than to succeed in imitation.
Pathfinder Tags: heat transfer
Re: How to increase heat transfer/reduce contact resistance
10/15/2013 6:54 PM
Use copper....?
10/15/2013 6:57 PM
Are these surfaces metal?
Thermal grease.
Copper, or better yet silver, powder filled grease.
Solder.
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
10/17/2013 8:46 AM
Thermal grease would be my suggestion.
Here's some:
http://www.novagard.com/compounds/Thermally-Conductive-Compounds.html
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
10/20/2013 8:06 AM
OK Gold dust
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
10/20/2013 10:11 AM
Wrong, buffalo breath!
Ag has higher thermal conductivity than Au.
10/20/2013 3:13 PM
Diamond dust!
Au k≈315
Ag k≈420
Diamond k≈2200
If you wish to go for the absurd, Graphene k≈4840
10/15/2013 7:30 PM
It really depends on the surface materials and what you are trying to accomplish. You have asked for two very different things by the way.
What will work with plated microchip pins won't necessarily work with a 220kV aluminium overhead power joints (for example).
Please provide much more information in greater detail.
Re: How to Increase Heat Transfer/Reduce Contact Resistance
10/15/2013 11:43 PM
They are relatively flat only when both surfaces are in thermal equilibrium with each other. Bolting these two surfaces together will further distort the surfaces. Adding a thin amorphous media (thermal grease) between the two surfaces will allow the voids created by these deformations to be filled with a more thermally conductive media than vapors.
10/15/2013 11:47 PM
And both surfaces are the same material, or have the same coefficient of thermal expansion.
10/17/2013 8:43 AM
How much heat are you starting with?
How much transfer are you starting with?
What is the desired increase in heat transfer?
What are the surfaces made of?
How much contact resistance are you starting with?
How much contact resistance do you want?
What is the required contact area?
What type of bolts are required?
How much torque is required on the bolts?
Are there any restrictions on materials to be used?
etc. etc. etc.
Another solution looking for a problem to solve?
Good Answers: 58
10/17/2013 9:03 AM
The question is too general for us to provide a specific answer. We need details on the materials involved. the bolting pattern, and the environmental conditions.
10/17/2013 9:14 AM
You could go esoteric and put a Peltier device between the surfaces.
I also have immersed my heat sink into liquid nitrogen. The heat transfer rate is tremendous.
Good Answers: 122
10/17/2013 9:53 AM
Silver plate both mating surfaces and use thermal heat sink grease between them.
There are water soluable silver plating powder compositions on the market that are easy to apply,cost effective, and work well.
The compositins are easily applied by hand using a sponge, scuffing pad, or a rag.
Both mating surfaces must be very clean with no oily contaminants present.
Be sure to read and follow the application directions carefully.
Good Answers: 183
10/19/2013 3:31 PM
The first question is: why do you need to increase? In general heat transfer across surfaces bolted together and with a not too bad roughness is about same as base material. Thus the question. If you have a too low heat transfer which means that you obtain a high temperature difference between the 2 flanges then they are not in contact as they should: check roughness and planeity of both. It could be possible that the surface is too small and then you should increase the flanges as diameter. The use of a cooper layer has to be considered with care since you loose assembly stiffness and the preload can decrease too much in use and too fast. Grease can be good but it depends on the temperature domain.
Good Answers: 58
10/20/2013 5:18 PM
There are many things one could do to reduce contact resistance, but these are solutions looking for a problem that has not yet been defined. One could improve the surface finish, but if the heat transfer surfaces are in a vacuum, that solution won't be effective. The guys at NASA can explain this. You could use thermal grease between the surfaces, but you will run into temperature limitations. You say there is no temperature restriction? Well, you might have informed us! Same is true for corrosion. I could tell you that we use pure woven silver screen sandwiched and compressed between silver plated rigid copper bus bars, but you would probably find a reason why that won't work for you, perhaps cost.So, as I suggested previously, you define the problem and we will try to help you solve it.
10/20/2013 5:58 PM
I take exception to, "heat transfer surfaces are in a vacuum, that solution won't be effective."
Vacuum only negates convection. Conduction and radiation still obey the laws of physics.
I didn't work directly for NASA, but I'm one of those "guys".
Good Answers: 58
10/20/2013 7:27 PM
Sorry, change that "to may not be as effective". My point remains.
10/20/2013 7:45 PM
Actually, two surfaces in intimate contact rely very little on convection.
In space, conduction only works when there is a conductive (probably metallic) path for the heat. To get heat out of the system, into space, we had to rely on radiation alone.
Good Answers: 183
10/21/2013 1:12 PM
There is some truth in what he wrote although the error was to consider convection. In a contact situation the air (gas) layer is too thin to allow a true convection so that heat will be transferred by "conduction". In a vacuum this little part of conduction will be zero and only direct metal to metal conduction will work so that there is a heat transfer reduction even if VERY small.
10/21/2013 1:18 PM
I'd call the non-contact movement of heat between the two surfaces radiation, not conduction.
But, the amount is hardly worth debating.
Good Answers: 183
10/21/2013 1:39 PM
Radiation being proportional to (T1^4-T2^4) if differences are small is neglectable.
10/21/2013 2:30 PM
Ok we have all made plenty of guesses, what exactly are you after?
What is the exact application.
10/21/2013 2:39 PM
That would be telling.
10/21/2013 2:46 PM
Saying would be knowing, do not know so cannot say.
Register to Reply 24 comments
jack of all trades (3); JCase (1); JP76 (1); lyn (6); nick name (3); redfred (4); SHOCKHISCAN (1); SolarEagle (1); Tom_Consulting (1); welderman (3)
