Previous in Forum: Transformer Input Voltage Problem   Next in Forum: Three Phase Toroidal Transformer Design
Forward Converters
10/16/2013 2:59 AM
I have been given a HW problem to find the duty ratio of forward converter when the reset winding is connected to the secondary side. I have to calculate the duty ratio for this circuit.
Re: Forward converters
10/16/2013 4:34 AM
Well then, go ahead and run the numbers.
Let us know the answer when you're finished.
10/16/2013 4:43 AM
That is a fine assignment. We are looking forward to your solution and presentation of the results.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
10/16/2013 4:50 AM
https://en.wikipedia.org/wiki/Forward_converter
BSEE but always learning
10/16/2013 6:08 AM
Hear, hear. Good luck with that.
10/16/2013 7:36 AM
the sooner you run your calculation the sooner you can move onto homework question #2
Good Answers: 50
10/16/2013 7:46 AM
This circuit predates me. I think it's a MAG-AMP. Not sure, as differential amplifiers in IC form took over the world of autopilots, and I never had to do any cognizant work on the 1950-60s stuff. Too bad there's no tubes (or valves) in the circuit diagram to make it real fun.
ignator -
Register to Reply 6 comments
1capybara (1); Fredski (1); IdeaSmith (1); ignator (1); lyn (1); PWSlack (1)
