Previous in Forum: Body Panels as Storage Devices?   Next in Forum: General
17 comments
Need Help Finding Bolts
10/22/2013 9:37 PM
Looking for grade 8 3/4" x 16 x 2 1/2" Left handed thread bolts.
Does anyone now who has these. Have to make adjustable radius rods so need left hand can find 3/4 x 10 bolts but not 3/4 x 16 they make nuts so you would think they have bolts
Re: Bolts
10/22/2013 10:07 PM
oops
Re: Bolts
10/22/2013 11:30 PM
Fastenal
Re: Bolts
10/23/2013 7:40 AM
Not Fastenal or McMaster Carr Been there they have 3/4 X 10
Good Answers: 21
Re: Bolts
10/23/2013 12:07 AM
McMaster Carr
Re: Bolts
10/23/2013 12:31 AM
oops
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
Re: Bolts
10/23/2013 6:52 AM
you can try speciality hardware mfg's like:
www.huronauto.com
Nothing is fool-proof to a talented fool
Re: Need Help Finding Bolts
10/23/2013 12:50 PM
Have you looked for turnbuckle hardware? A source like that might have something you can use.
10/23/2013 1:00 PM
Yeah I have, problem is that they are not grade 8
Good Answers: 445
10/23/2013 2:13 PM
This place stocks 10 tpi, advertises they make any size to order, doesn't look cheap though:
http://www.mutualscrew.com/Left-Hand-Fasteners/left-hand-grade-8-tap-bolts-full-thread-11074.html?gclid=CJTj36_GrboCFQSk4AoddW0Agg
10/23/2013 3:10 PM
Who specified something that is unobtainable?
10/23/2013 11:21 PM
Try a fastener specialist. In Canton, OH, there is Ziegler's, sometimes jokingly called the nut house.
Lehman57
10/24/2013 8:24 AM
Have you tried
http://www.thomasnet.com/products/lefthand-screws-72660350-1.html
Canada - Member - New Member
10/24/2013 8:49 AM
Not really a common size. You will likely end up paying quite a bit for them, so, try your local machine shop. If I recall, if you really need Gr 8 strength, 4140 steel, heat treated after machining should give you that strength.
Never stop learning
10/24/2013 8:55 AM
Yeah thats kinda where Im headed, Have Lathes and material and have access to heat treating oven, It would be easier to just buy them but not having any luck.
Thanks
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
10/24/2013 8:57 AM
Try these guys, I believe they can make you anything, if you want them to.
http://timberlinefasteners.com/contact/
Good Answers: 27
10/24/2013 9:51 AM
Check with a lawn-mower repair shop. Our tow behind mower uses 3/4-16x2 LH gr.8 bolts for mounting the blades. They may have other sizes available for blade/pulley mounting.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
10/24/2013 8:01 PM
I once worked for Fastenal, they may not have them in stock sitting on their shelf but they can get any fastener, any pitch, any grade or have them made if needed. Like any supply house, they are driven by profit margins and gross sales. It's just not worth their time to order a few but if you say you'll order 10 and pay $5.00 each they will deliver them to your house.
A local machine shop ( jobber - not CNC production) might hook you up for less hassle.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Register to Reply 17 comments
ceverette (3); fixitorelse (1); JCase (1); Kevin LaPaire (1); Lehman57 (1); lonster (2); lyn (3); markar (1); phph001 (1); RAMConsult (1); tiger93rsl (1); Usbport (1)
