Previous in Forum: Energy Saving in Pump Station   Next in Forum: Tube Sagging in a New Heat Exchanger
13 comments
DAEWOO P222LE
10/23/2013 9:18 AM
We are trying find the engine timing mark in fly wheel in DAEWOO P22LE engine. But not found.
Requested for inform us where we found the fuel timing mark to do fuel timing. Engine power 574 kW, number of cylinder 12V. Bore: 128 mm, stroke: 142 mm.
Re: DAEWOO P222LE
10/23/2013 9:39 AM
Look on the camshaft sprokets.
Re: DAEWOO P222LE
10/23/2013 9:53 AM
Re: DAEWOO P222LE
10/23/2013 10:00 AM
Re: DAEWOO P222LE
10/23/2013 10:35 AM
Good Answers: 102
Re: DAEWOO P222LE
10/25/2013 1:18 AM
GA even though it doesn't have the answer the OP seeks.
That O&M manual has some good info in it, OP can add that to his library..but the OP probably needs the Service manual if he is performing a procedure that requires timing.
Re: DAEWOO P222LE
10/25/2013 5:09 AM
It doesn't?
Oh well. I didn't read the whole thing, but saw the timing section and figured it would be in there.
Lots of good general info though.
Re: DAEWOO P222LE
10/23/2013 2:13 PM
fuel timing? that's a new one. I've hear of ignition timing from a crankshaft/balancer
Re: DAEWOO P222LE
10/23/2013 3:12 PM
Diesel? With mechanical fuel pump?
Re: DAEWOO P222LE
10/24/2013 1:36 PM
Probably a diesel engine, thats how at least some are set up....my old Mitsubishi 2.3 Liter for example.
Good Answers: 102
Re: DAEWOO P222LE
10/25/2013 1:20 AM
Fuel timing for fuel injection.
Re: DAEWOO P222LE
10/25/2013 7:39 AM
Hold the train.
This is from the OP.
Good Answers: 102
Re: DAEWOO P222LE
10/25/2013 1:45 AM
Fellas, look at the description the OP gave. It's a big diesel engine. Some 700HP big.
A genset most likely.
I'm guessing that the OP has had the injector pump/metering unit out for servicing and recallibration and needs to find TDC on #1 cylinder as part of the reassembly procedure.
If the OP can't find a TDC mark at either the flywheel or the harmonic balancer end then he may have to resort to opening a crankcase cover so he can see #1's crank and open the rocker cover(s) on #1 and look as the crank is slowly rotated for when #1 is at the top of the stroke and both inlet and exhaust valves are closed.
Once OP has gone through all of this bother he will probably then notice some obscure marks that might sort of line up if you squint......or not, but either way he has TDC on compression stroke for timing reference.
Maybe OP can tell us why he needs the timing mark?
Good Answers: 102
Re: DAEWOO P222LE
10/25/2013 1:57 AM
Service manual $14.95 to download.
Register to Reply 13 comments
Andy Germany (1); Fredski (1); kramarat (3); lyn (3); SolarEagle (1); Wal (4)
