Previous in Forum: Difference Between ASME Power Boiler and Heating Boiler   Next in Forum: Underground Garage Ventilation
18 comments
Vibrations
10/28/2013 5:17 AM
We have a Gas Turbine Alternator using twin avon jet engines by rolls royce to drive a generator/alternator as the prime mover.
After an overhaul of the system and putting everything back in place, we have since experienced vibrations trippin the machine on extreme vibrations. What could be the possible miscalculation?
Re: Vibrations
10/28/2013 5:20 AM
Did someone leave a "shifter" inside it?
Reply Score 1 for Off Topic
Re: Vibrations
10/28/2013 5:46 AM
No we made sure of that
Re: Vibrations
10/28/2013 6:05 AM
That was a joke...
Anonymous Poster #2
Re: Vibrations
10/28/2013 6:08 AM
This is not 'shifter'! This is called 'paiepe wrenchh'
Reply Score 2 for Off Topic
Re: Vibrations
10/28/2013 6:14 AM
Not round here, it isn't. Try getting hold of a <..paiepe...> with that and it will only lead to disappointment.
"AFS spanner" is another term for this tool (full explanation withheld on grounds of decency, except that the A stands for "any" and the S stands for "size"!).
Reply Off Topic (Score 6)
Re: Vibrations
10/28/2013 11:01 PM
Another name is adjustable spanner
pnaban
Re: Vibrations
10/28/2013 10:55 PM
In New Zealand that device is called a nut f....er.
Re: Vibrations
10/28/2013 6:11 AM
The best people to ask are those that form the team that have been working on it prior to its reassembly. Use of the word <...We...> implies that there are at least two of them, after all.
Quite what a bunch of well-meaning, anonymous strangers are supposed to bring to the party is anyone's guess.
<unsubscribes>
Anonymous Poster #2
Re: Vibrations
10/28/2013 6:14 AM
They can do an radiography of the complete equipment to rule out the possibility of any entrapped tools..
Re: Vibrations
10/28/2013 6:15 AM
Please address the remark to the original poster instead.
Re: Vibrations
10/28/2013 6:56 AM
Lots of things.
Did you follow the proper shut down and cooling procedure before tearing it apart?
If not, you may have warped the shaft.
Bearings could have been installed improperly.
Regardless...you'll find out what you did wrong, when you tear it back apart. There's no other way.
Good Answers: 109
Re: Vibrations
10/28/2013 9:58 AM
In order to understand what you calculated wrong you might want to expand on what you calculated in the first place.
If with miscalculation you mean "mistakes" there might be plenty. What has been changed and why was the overhaul necessary?
Are both jets working with the same parameters?
This needs far more information to even make an educated guess than possible can be presented in an anonymos forum.
But as a second guess I think there might be an Irish Screwdriver missing in the toolbox . . .
Re: Vibrations
10/28/2013 11:07 PM
Are the shafts for-sure coaxial?
Lehman57
Good Answers: 117
Re: Vibrations
10/29/2013 12:11 AM
Here's a question.. why are you asking us?
Get them back in to fix it.. it's not rocket science!
Good Answers: 21
Re: Vibrations
10/29/2013 4:11 AM
Firstly, are you actually experiencing vibration ? Have you felt it, or is it just a reportable input from a field sensor (accelerometer) to the management system causing the trip?
Not uncommon for field sensors to require calibration/ become faulty etc..
I recall setting older Bentley Nevada accelerometers with an instrument called a 'Wobulator'...
Another possibility is the alignment, which should have been re-done from scratch, if either the generator or the turbine was loosened from their mountings.
In any case, too little information given to make an educated guess...what did your 'overhaul' comprise eg did you replace turbine blades, did you separate the generator from the turbine and overhaul at a remote location etc.. etc..
Good Answers: 117
Re: Vibrations
10/29/2013 7:07 AM
can I get the spec on that "Wobulator"?
Is it made by the same company that makes the "gangaling pin"?
Re: Vibrations
10/29/2013 6:35 AM
Misalignement
Imbalance of the turbine rotating elements
Some items missed/forgotten during re-assembly.
Did not follow a strict procedure for this operation (Dismantling-replacing-reassembling), which is supposed to be outlined in a document or manual ...
Should have brought in qualified Rolls Royce team to do the job and they would have been responsable for the outcome.
Good Answers: 102
Re: Vibrations
10/29/2013 7:07 AM
Do you have a vibration issue when the alternator is disassociated from the engines?
How about when only one engine is coupled to the load? (you said twin)
Is there a gear box between the turbines and the alternator in this set up?
Pulling the thing down is the only way to find out where you miscalculated ( is that the same guessing incorrectly?), but as you take it apart try to run it (if possible) as you go in differing states of assembly. You may not have to pull it completely apart.
Apart from firing this up is there any other way of rotating the assembly?
How about answering some of the other questions from the less flippant correspondents here? ( i have to confess that i was tempted to post a picture of a socket set with an empty slot in it..not helpful)
Reply to Forum Thread 18 comments
Anonymous Poster (2); brich (2); Hilton (1); IdeaSmith (1); kramarat (1); LAA_Lucke (1); Lehman57 (1); Oraka (1); pnaban (1); PWSlack (5); Wal (1); Xtreme (1)
