Previous in Forum: Underground Garage Ventilation   Next in Forum: Descaling Firetube Steam Boiler
26 comments
What is the Best Base for a Hot Tub?
10/29/2013 2:38 PM
I am putting a hot tub in my back yard. I have learned cement/concrete and gravel are best. Gravel got slightly higher marks and is cheaper and faster. I have located mixed results whether the gravel should be compacted. Apparently, gravel will settle a little reducing stress on the hot tub low points on the hot tub letting them sink. The gravel will be dumped into a frame made from 2x6 then leveled at 5". Should the frame be secured with stakes? I was able to gleen this from several do it yourself hot tub sites. I am wondering what an engineer would say.
Thanks!
Re: What is the Best Base for a Hot Tub?
10/29/2013 2:58 PM
I's say contained gravel would be fine.
Yes, stake it, on the inside so they don't show.
Happy soaking.
10/29/2013 3:00 PM
an engineer is never going to suggest cheap or flimsy! get out the I- beams and piledriver
10/29/2013 3:02 PM
Did somebody mention bedrock.
10/29/2013 3:26 PM
I would go with gravel or sand and put an extra layer of solid 2 inch foam insulation between the tub and the ground. They tend to be rather poorly insulated on the bottom plus the foam will crush just enough to give you the most equal weight distribution.
10/29/2013 4:30 PM
As any true hot tubber will tell you, it's not what you put under the hot tub, it's what you put in it....
10/29/2013 4:36 PM
What about Base64. Base64 sounds like a good way to get into some hot water. Particularly if you think that this is a safe way to encrypt data away from the eyes of Edward Snowden.
Good Answers: 114
10/29/2013 5:33 PM
I would use crushed stone rather than gravel, gravel tends to migrate, the pebbles slide over each other too easily, something akin to seating the tub on a bed of marbles.
10/29/2013 5:37 PM
10/29/2013 10:51 PM
OOPS wrong button.
10/29/2013 10:35 PM
I wanted permanence and the 2-person Jacuzzi Tub manufacturer suggested a fine concrete mix (this is an indoor tub/shower). 2x8 supports on 8 inch centers with 1-1/4" plywood on top, then builder's paper and then the cement poured on top of that and spread out so it was just a bit taller than the bottom of the tub.
Set the tub on top if that and jiggled it until the tub edge supports grounded on their structural supports.
15 years later the tub is still solid with no bottom flex anywhere.
Saving money on construction materials is, in my opinion, a bad place to save. Labor is the big ticket in most cases in the U.S. A building will last at least 50 to 100 years and it would be nice to have the infrastructure last as long as possible.
I have foam supports under the plastic tub in my motorhome. The bottom flexes everywhere. Bad idea in my opinion to use foam.
It was burning when I put it down!
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
10/29/2013 10:37 PM
Possible problem with gravel sand or and form of crushed stone subbase unless compacted properly it could settle and cause the tub to become unlevel causing problems for the pump. That's why usually wood decks and concrete pads are the better choice. You might also want to check with your local government they usually will tell you what the local regulations and permits are.
John J Baker
10/30/2013 3:57 AM
check with your local government they usually will tell you...
...that you can't do it or must pay for the privilege, or will try and tax you on it.
Mum's the word...
(You ain't seen me... roight?)
Good Answers: 12
10/30/2013 9:33 AM
Until you try and sell you house and get nail on back taxes and permits been there done that. lol
John J Baker
10/30/2013 9:40 AM
Where I live you are supposed to get 'covenant approval' for all sorts of stuff... and it costs.
The daft thing is, you can do it retrospectively and and get approval for say 5 things, at the same cost as 1.
Anyhow, I don't see why I should get covenant approval for something which can't be seen from the road....(like my solar hot water panels)
I expect you can see why I posted....
Good Answers: 12
11/01/2013 11:58 AM
I agree but I also put a hot tub in my back yard at my place in PA never bothered getting any permits. 10 yes later when I put up my house for sale to move to AZ the township found out about the tub checkttheir records and put a $20,000 lien on my house. Luckily my company was willing to pay it as part of my moving and housing expenses to move out here. So its just a word or warning from personnel experience. Have fun with the tub.
John J Baker
11/01/2013 12:52 PM
checkt their records and put a $20,000 lien on my house...
Doesn't it warm yout heart how local government spends your taxes.
Couldn't you just fill it in and deny it ever existed?Del
Good Answers: 12
11/01/2013 2:10 PM
My present company gave me three weeks to pack and ready the house for sale the tub was part of the selling points plus I'm sure it was noted when I had my in the ground swimming pool put in two years before. The inspectors where a major pain. The pool was fully functional and they would not issue the occupancy permit for two months because they couldn't get an inspector there. Try and tell your 5 year old you can use the pool for two months during summer because of a permit.
John J Baker
10/30/2013 2:05 AM
TCMTECH had a great suggestion with the 2" foam under the tub. We have used this as standard procedure for installs for quite a while. One really should construct a rigid level platform for the tub to rest upon. Concrete is probably the best but a well constructed wood deck will do fine. Any differential settlement under the tub could wreak havoc with the plumbing connections etc. For my tub I precast a concrete deck and placed it on two concrete footing strips so it could be re-leveled in the future should the sheltering trees cause problems with their root structures. Probably overkill, but if building a wood platform you can purchase support brackets with leveling screws that would afford the same flexibility. Whatever the case, the most important thing is to get it installed, filled and enjoy.
10/30/2013 3:06 AM
What is the connection between Cement, Gravel, Concrete and Mechanical Engineering? ROFL
Pls move this crap to Civil Engineering section!
10/30/2013 3:28 AM
Why don't you move to the Uncivil Engineering section?
10/30/2013 9:37 AM
Better yet, move to another forum.
10/30/2013 11:59 AM
I'm going to guess you're artsmith in the AP1 troll suit.
10/30/2013 10:28 AM
Thanks for the input! I never thought about putting foam down. I am assuming a lack of consensus means any of the above will be OK. I will go with CR6 which costs $20/ton and the delivery is cheap being only a few miles from the closest source.
I put crushed stone and gravel in the same category. I have used CR6, a road foundation, for a shed base over 10 years ago. The deepest parts are over 18". I live on a hill and have little level ground. The shed is 25' long. The high edge of the ground where the shed now lies was removed and the low points were filled. I double-checked the settling last evening. The bottom of the shed is a framework of 2x4s set edge-wise. Where I could see the 2x4s settled into the crushed rock, it was surprisingly uniform, about a half inch whether the 18" or 6" deep. The foundation had been sitting for about a month before the shed was laid. Crushed rock tends to solidify over time and rain speeds up the process. The foundation probably have at least a dozen thunderstorms before the was delivered. Our area usually has a short violent thunderstorm every evening in June and July. The shed manufacturers suggested finishing the foundation before starting the work order. That gives the foundation about a month to harden.
This is a tiny project about 1 ton of CR6 vs 7. I will rent a vibrating compactor to speed up the settling process. The best part about a gravel/CR base is if we or the next owners want a bigger hot tub they will not need jack hammers to remove the old base. We are over sizing the base by a few inches for this and other reasons. Anyone can add and possibly remove some of the base to accommodate a new spa height. This is replacing an old hot tub sunk into a deck but supported from a base. The old one had a wooden base custom made to support the hot tub supports. This new design allows us to use a freestanding hot tub.
By the way Mr Anonymous, I searched for something like concrete in both Civil and Mechanical Engineering and there were many more hits in Mechanical so I placed the query here.
10/30/2013 10:37 AM
after you pour your stone (assuming you're passing on concrete) make sure to use one of these.
Good Answers: 12
10/30/2013 2:12 PM
Jumping jack is another tool that will give you compaction.
John J Baker
11/01/2013 11:01 AM
you should put it in my yard for about a year to test run the system. you are welcome to come by every couple of months and try a different base until you find the best fit.
CARPE CRUSTULORUM!
Register to Reply 26 comments
aDIYguy (1); Anonymous Poster (1); bakerjohn (5); Fredski (2); lyn (4); mrehmus (1); not so smart (1); passingtongreen (1); redfred (2); SolarEagle (1); Sourdough (1); tcmtech (2); Tornado (1); user-deleted-1105 (3)
