We need to reset from the plc the actual value of an absolute
encoder of a servomotor. How can we do this? We are using the following hardware. Thank you
PLC CPU 313C-2DP COMPACT CPU WITH MPI, 16 DI/16 DO, 3 FAST COUNTERS (30 KHZ),
INTEGRATED DP INTERFACE, Siemens 6ES7313-6CG04-0AB0
Control Unit SINAMICS
CONTROL UNIT CU320-2 DP WITH PROFIBUS INTERFACE WITHOUT COMPACT FLASH CARD
Siemens 6SL3040-1MA00-0AA0
Memory Card SINAMICS
S120 COMPACTFLASH CARD WITH FIRMWARE OPTION PERFORMANCE-EXTENSION INCLUDING
CERTIFICATE OF LICENCE V4.05 Siemens 6SL3054-0EF01-1BA0
Double motor module
SINAMICS S120 DOUBLE MOTOR MODULE INPUT: DC 600V OUTPUT: 3AC 400V, 5A/5A
Siemens 6SL3120-2TE15-0AA4
Servomotor SIMOTICS S
1FK7 COMPACT 8 NM, 100 K, 3000 RPM, 2,14KW , ABSOLUTE ENCODER 2048 P/REV
(ENCODER A-2048) WITH DRIVE-CLIQ INTERFACE; Siemens 1FK7080-5AF71-1FB2
