Previous in Forum: Add Another Nozzle at the Pipe of a Nozzle? (ASME Pressure Vessel)   Next in Forum: PWHT/Stress- Relieving
9 comments
Impact Test
11/01/2013 1:50 AM
Impact test is done for materials which fall below UCS-66 curve A,B,C or D(depending on materials). For example, for SA 516 Gr.60 (Normalized), MDMT is -48° C.If the minimum design temp. is colder/lower than -48°C then Impact test is required.
My question is: How will impact test help in this situation? Why should we perform impact test?
Regards
Pathfinder Tags: impact test
Good Answers: 109
Re: Impact Test
11/01/2013 3:38 AM
Brittleness when cold?
Re: Impact Test
11/01/2013 3:58 AM
Ask cxcxcx0505.
Anonymous Poster #2
Re: Impact Test
11/01/2013 10:02 AM
Did you ask this question to Mr. Pvelite?
Good Answers: 104
Re: Impact Test
11/01/2013 12:47 PM
The general idea is that if the material fails the impact test requirements for that MDMT, items made from that heat will not be allowed to be used at that temperature. It is an additional requirement to SA 516 Gr 60 for that special case.
Anonymous Poster #2
Re: Impact Test
11/02/2013 12:37 AM
Rudeness and cursing Not Tolerated on CR4
Removed by CR4 Admin.
Re: Impact Test
11/02/2013 3:44 AM
Sir
Please note that my question was no where your answer. The impact test is done to check the absorebed energy in the specimen are within ASME code (UG-84) limits. Table UCS-66 (Impact test Exemption Curve) listed materials in this regard. My concern was what is the basis of selecting energy limit by ASME?
And for you, MDMT is the lowest temperature permitted according to the metallurgy of the vessel fabrication materials, that is, according to the low temperature embrittlement range and the charpy impact test requirements per temperature, for each one of the vessel's components
Cursing removed - CR4 Admin
Re: Impact Test
11/02/2013 3:53 AM
Don't worry about AP#2, who is not really knowledgeable, nor even humorous.
Anonymous Poster #2
Re: Impact Test
11/04/2013 1:19 PM
United States - Member - New Member Hobbies - Automotive Performance - New Member
Re: Impact Test
11/04/2013 10:05 AM
Sorry for the rude responses you received in regards to your question Anny. Using the anonymous post feature to be rude to another user is very annoying and abuses the feature. I hope you get the answers / help you are looking for.
Register to Reply 9 comments
Anny (1); Anonymous Poster (4); Baxter (1); bigg (1); IdeaSmith (1); Tornado (1)
