Previous in Forum: 110V DC Power Supplies Through 240V AC UPS to 110V DC Converter   Next in Forum: Smart as in Home?
14 comments
No Load Line Voltage
11/03/2013 6:35 AM
In a 50 kVA, star connected 440 V, 4-phase 50 Hz alternator, the effective armature resistance is 0.25 ohm per phase. The synchronous reactance is 3.2 ohm per phase and leakage reactance is 0.5 ohm per phase.
so the no load line voltage will be ??
Re: no load line voltage
11/03/2013 6:41 AM
Study before it's time for the test!
Tips for Posting on CR4:
  • Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
  • Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
  • Buy the book!
11/03/2013 8:20 AM
here's a hint...if you have a homework question you're too lazy or unable to figure out for yourself and you'd like a freebie from this forum then formulate your question as if you're actually encountering this issue in the field and I'm sure several people here will suggest what measures you need to take to arrive at a solution. but since no one here thinks this is anything but homework, you'll get smart ass responses good luck
Good Answers: 141
Re: No Load Line Voltage
11/03/2013 1:57 PM
Something tells me you think square. 4 phase alternators are not so common. I am still figuring out how to connect that in star. Is it a 4- point star, like 5 point star, minus one?
Plenty of room here
11/03/2013 2:04 PM
I might be wrong but I took it as "polyphase" who knows?
11/04/2013 7:07 AM
i guess ,am not sure ....
temme if there is any formula for no laod line voltage ?
Good Answers: 117
11/04/2013 6:49 PM
"i guess ,am not sure ...."
about what?.. The question you have asked or the question you were asked? I'm not sure now!!
11/04/2013 6:57 PM
11/04/2013 9:03 AM
Point well taken. I think he looked at the star and counted the neutral as a phase. Oy!
11/03/2013 2:41 PM
11/03/2013 7:51 PM
Quote Khans "In a 50 kVA, star connected 440 V, 4-phase 50 Hz alternator"
Maybe he means 4 wire instead of 4-phase.
11/04/2013 3:35 AM
It is rather difficult to tell which.
Good Answers: 102
11/04/2013 11:20 PM
Others have already suggested that you mean 4 wire (ie 3P1N) not 4 phase.
50kVA/440V/"3"P/Y sounds like a bog regular genset for say a small office/apartment/hotel/workshop......
so the no load line voltage will be???
....it will be what ever you set the AVR to. This setting should be taking into account any voltage drop of the distribution network you energise with it.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
11/19/2013 10:44 AM
440v line to line, 254v line-gnd.
BSEE but always learning
04/18/2014 6:11 AM
I just read the forum after a long absence for two years or so.
In star connection:
1. V (L) = 440 V; V (L) is the line voltage.
2. V (P) = 440 V/1.73 = 254.3 V; V (P) is the phase voltage.
Generally: For 3-phase system V = 400 V and phase Voltage = 230 V
The no-load voltage would appear to be slightly greater than full-load voltage?
Register to Reply 14 comments
1capybara (1); abasins (1); brich (1); dvmdsc (1); Fredski (2); khans (1); lyn (3); nitroxpro (1); PWSlack (1); Wal (1); wareagle (1)
