Previous in Forum: Voltage Transformer Question   Next in Forum: Double Phase MCB used as Single Phase MCB with Neutral
Testing, Charging And Monitoring A Single Cell of NIMH
11/11/2013 1:24 PM
Do you have a circuit on how can I Test, Charge and monitoring a single cell of NIMH. I have a tester and some teory about charging this type of cell, but individually not on a battery . Thank you in advance.
Pathfinder Tags: NIMH cell.
Re: Testing, charging and monitoring a single cell of NIMH
11/11/2013 1:38 PM
Re: Testing, Charging And Monitoring A Single Cell of NIMH
11/11/2013 10:23 PM
11/11/2013 11:56 PM
look at the LTC4060, LTC4010, LTC4011
at www.linear.com
They have app notes and design examples
11/12/2013 1:21 PM
Is this maybe homework? Then you already have your answer(s)!
If not, all I can say is that usually today, you just buy an intelligent charger that will "look after" the cell properly. They are so cheap nowadays...
11/12/2013 6:40 PM
no i don't have a circuit - a tester might stand for multimeter ... highly sophisticated specialized lab apparatus intended for speciffic capacity and model (e.g what time it is on earth?)
if you need to reject a black lamb from a set - you should probably charge and discharge the items - the higher internal resistance units tend to get less charge if charged as a cell-pack - t.m. your starting conditions vary by cell not meaning the low voltage items should rejected without futher testing - if you have enough of the cells in hand you can regroup similars by test result ...
you have to keep count on coulombs that enter (-thermally escaped = ) coulombs that exit (-thermally escaped) + to adequately evaluate this you need T(°C/K/e.c),U(V),Q(C),"operational age of battery"(hours?/charge discharge cycles?/el-luthe condition?) map in hand for your specific cell
the grid would vary on your budget and setup - why don't image search for "NiMH lab" or alike
ci139
Andy Germany (1); Brave Sir Robin (1); ci139 (1); SolarEagle (1); WAWAUS (1)
