Previous in Forum: Remote Sensing of Water   Next in Forum: Memory Backups
Switches for Compressor/Pumps in Local Panel/System
11/20/2013 11:25 AM
What is the basis of considering Selector swithes in field/control system and where should this be considered, in field or should be in the system. Eg. Local remote selector, Auto/manual, Local reset/ Remote Reset etc...
Re: Switches for Compressor/Pumps in Local panel/System
11/20/2013 11:33 AM
in an automated system(controlled by a computer or programmable unit it is necessary to operate the machinery for service and maintenance purposes. in these situations a "Field or manual" switch is needed to bypass the computer program and force a start of individual components such as a fan or pump. waiting for a timed start might take hours. the system needs to have the ability to be over-ridden in the field for testing
11/20/2013 11:50 AM
In the normal course of events these controls would be mounted on the cubicle door for the starter in question, although it is not unknown to use a local control station next to the equipment itself. Local circumstances will determine the correct approach and those cannot be seen from here.
11/20/2013 12:48 PM
Such consideration should be left to the process engineer, controls engineer and the maintenance engineer who will together design the system.
Too much detail has not been given here for a competent answer.
Re: Switches for Compressor/Pumps in Local Panel/System
11/21/2013 9:00 AM
This decision shall be taken by process engineers in consultations with operations people. Also during process HAZOP this will be evaluated . There is no standard or guidelines, its more a question of operational philosophy adopted by a company/ operator.
Register to Reply 4 comments
Fredski (1); instruguy72 (1); lyn (1); PWSlack (1)
